blinker problem
Old Jul 18, 2004 | 11:25 AM
gsr-2nr's Avatar
Default blinker problem
1st YES i tried searching but found nothing that helped me. my blinker on the front passanger side is blinkng fast the large bulb is. i replaced the bulb a couple of weeks ago and it stopped but when i went to work this morning it started again and now the bulb itsnt working and i put 2 different ones in there and the large bulb is getting no power. and every other bulb works but this doesnt. what is wrong the harness is in i disconnected it and put it back in but it still does it. so someone help
Old Jul 18, 2004 | 11:33 AM
1GreyTeg's Avatar
Default Re: blinker problem (gsr-2nr)
A short possibly?
Bad bulbs?
Your guess is as good as mine. Maybe someone else can shed more light.......
I clicked this thinking it was another link asking "how to make the lights blink faster", and was almost equally rewarded.
Oh well.
Old Jul 18, 2004 | 11:37 AM
gsr-2nr's Avatar
Default Re: blinker problem (1GreyTeg)
i checked all the bulbs they r all fine its just this one 4 some reason. the little bulb works but not the large
Old Jul 18, 2004 | 11:43 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">i checked all the bulbs they r all fine its just this one 4 some reason. the little bulb works but not the large</TD></TR></TABLE>
Did you check with a mulitmeter?
http://081368.tripod.com/diags/motoragejune98.htm
Old Jul 18, 2004 | 11:44 AM
mike0980's Avatar
check the blinker fluid!!
Old Jul 18, 2004 | 11:46 AM
1GreyTeg's Avatar
Default Re: blinker problem (mike0980)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike0980 &raquo;</TD></TR><TR><TD CLASS="quote">check the blinker fluid!! </TD></TR></TABLE>
dork
That was old on the last blinker post.
Old Jul 18, 2004 | 01:00 PM
Im_In_There's Avatar
check the connector on the bulb socket and make sure it is not bent. I had a similar problem and it was due to a bent connector inside the socket. If it is bent just bend it back and slide the socket back into the harness.
Im OUT .....1
edgar
Old Jul 18, 2004 | 01:49 PM
Misfit's Avatar
Default Re: blinker problem (Im_In_There)
back in the old days of it being cool to have fast blinkorzzz. I had a problem with the bulbs I was using...
are your bulbs stock or OE??
Old Jul 18, 2004 | 01:55 PM
uNF$@#!'s Avatar
Default Re: blinker problem (misfit)
check the blinker fluid level. if its below "Min" that would cause the blinkers to go fast too
Old Jul 18, 2004 | 04:53 PM
gsr-2nr's Avatar
Default Re: blinker problem (Captain Commando)
found the prob the socket is bad tried bending the connectors but it still did it so ima just get another one
lmike6453
Mar 5, 2008 05:02 PM
garrettej8
14
Dec 22, 2006 09:24 AM
kylem
Jul 24, 2004 03:45 PM
AK94GSR
Mar 27, 2002 02:27 PM
xevanx
Feb 23, 2002 05:49 AM
