aww my left headlight died.
well as the title states, my left headlight died...i havent gotten around to pulling the bulb, but from what i can see...the bulb looks fine...
so what else could it be?
H-T White Ops
I can't usually tell what's wrong with the filament until I pull the bulb.
A lot of times, the filament just looks kind of fuzzy, but is still intact. This is just an old bulb.
Don't worry about it and just pull the bulb out and replace it.
If you replace the bulb with a new one and it still doesn't work, then maybe start worrying.
well some funny stuff i found out today...all the fuses were intact and fine, my highbeams on both bulbs work...but my regular beams dont...
would a bad bulb cause that??
H-T White Ops
Re: (jasony0630)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasony0630 »</TD></TR><TR><TD CLASS="quote">well some funny stuff i found out today...all the fuses were intact and fine, my highbeams on both bulbs work...but my regular beams dont...
would a bad bulb cause that??</TD></TR></TABLE>
There are two filaments in a 9003 / H4 / HB2 light bulb.
One filament can burn out while the other continues to work just fine.
Both high beams, both low beams, or all lights going out at once would be strange and could indicate a problem.
Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">
Both high beams, both low beams, or all lights going out at once would be strange and could indicate a problem.</TD></TR></TABLE>
You are absolutely correct. Just remember buy QUALITY headlights, dont try any of those cheapo fake off road only HID lookalike crap, please. My friend scared me half to death driving me home one day with his, he had high beams on and you could barely see... Just be careful, get new headlights and you are set .
lol...
my headlight bulbs were made by hella, and they worked really well...until the filament died (i guess).
well i guess i'll have to go buy some bulbs tomorrow...
Re: (jasony0630)
If new bulbs don't work. Check Fuse box under the hood and under your change holder. Or make sure wires aren't touching some part of metal in your car or each other.
H-T White Ops
Re: (EK_kidd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_kidd »</TD></TR><TR><TD CLASS="quote">If new bulbs don't work. Check Fuse box under the hood and under your change holder. Or make sure wires aren't touching some part of metal in your car or each other.</TD></TR></TABLE>
He said his fuses look fine, but sometimes that doesn't always means the fuses are fine.
hondachris1994
09-02-2010 08:10 AM
Night Kid
09-12-2001 08:42 PM
