96 lx doesnt start when hot(not the relay)
like it says.no cranking or anything.if i drive it,then turn it off,then try to restart.......nothing.if i wait an hour or two.it fires right up.
this isnt a relay problem.so please dont respond with that.this is a ignition switch or starter problem.just wondering if this has happend to anyone else.thanks.
Re: 96 lx doesnt start when hot(not the relay)
maybe the starter is getting too hot and dont turn over when its that hot. you should pull your starter of and take it to be tested at autosone since you have rulled or relays
If you want to point your fingers at the Ignition or Starter, I'd start with check the ignition switch. I'd probably just turn the key to start and wiggle it around and see if it starts. Sometimes if the Ignition Switch is going bad it'll work.
Good Luck.
Good Luck.
sound like to me u got ignition switch problem. car wont cut off while running. i gotta be switch made it to turn off.. to check it while the car is running wiggles the key see anything happen or try to turn key back just a touch see car cut off..
carve
09-12-2009 09:35 PM
st_rage
11-29-2008 01:38 PM
Honda Virgin
06-02-2004 12:34 PM
