5th gen accord rear camber washer trick guide and how to
#27
Re: 5th gen accord rear camber washer trick guide and how to
i have i believe dropzone lowering springs (purchased car pre-lowered) is there any tricks for the front or is that only camber kit fixable
#31
MM Gruppe B
I would recommend locating parallel ground hardened washers.
Orchard Supply Hardware sells such washers.
FWIW, the washers appear to have the same markings as found on Honda bolt heads. The smashed '8' circle. I'll take a picture of both a Honda bolt head and Orchard washer if anyone so desires.
#32
Same Instructions as above, he was right on, here's some updated pictures. And some additional notes.
14mm socket (stock)
17mm socket (new)
ratchet (duh)
washers
The Parts:
The Culprits:
Bolts Out:
Comparison: (old = gold, new = black + 6 washers)
And Complete:
Difficulty Rating:
Hey can you post the pictures again? I am trying to gain some negative camber on the rear to tuck my tires inside my wheel wells.
Thnx!!
Modified by TheMuffinMan at 12:20 PM 9/14/2008
14mm socket (stock)
17mm socket (new)
ratchet (duh)
washers
The Parts:
The Culprits:
Bolts Out:
And Complete:
Difficulty Rating:
Thnx!!
Fuster_Cluck
02-04-2004 09:20 AM
Fuster_Cluck
07-10-2002 10:35 AM
fcuked
10
05-08-2002 09:18 PM
