5th gen accord rear camber washer trick guide and how to
Old 05-25-2005, 06:11 PM
jb.
jb.'s Avatar
Default FAQ: 5th gen accord rear camber washer trick guide and how to
To start off, I did this on a 95 accord ex 4dr lowered on Apexi WS coilovers. Use at your own risk. This is a fairly easy fix for your rear camber.
Here are the materials needed: 4 M10 x 1.25 x 50mm long bolts. Use atleast grade 8 if not higher. The grade 8s can be bought at advanced auto, but you have to ask for them. You will also need washers. I used smaller washers to fine tune it. The washers I used were SAE 3/8" (9,5 mm). I used 7 washers on each bolt, which fixed ~-2.15 and ~-2.06 on the rear. It took about 3 to take out a degree in camber. The stock bolts can take up to 3 on each bolt, I would not go any farther than that. Those are the new washers and the old small inadequate bolt.
Here goes:
1. Jack up the rear of your car and support with jack stands or two jacks. Make sure it is stable as the bolts my need a little persuasion.
2. Remove on wheel and you should see the bolts as pictured
4. Take them out and put the washers on the other side of the are against the body to push out the wheel. This will take two hands, one to hold the washers, and one to feed the bolt through.
5. Tighten the bolts back by hand pretty tight, replace the wheel, repeat on the other side, and then TAKE IT TO GET ALIGNED!!
Hope that helps everyone
Modified by jbkiksass69 at 9:06 PM 11/7/2005
At this time the pictures are not working in this post, if you scroll down to the post by TheMuffinMan he has posted new pictures from him doing this to his car.
TheMuffinMan's post with pictures
TouringAccord
Modified by TouringAccord at 10:14 AM 9/15/2008
Old 05-25-2005, 08:47 PM
AccordRacing's Avatar
I got an old Sprint kit for the 94-97 is someone wants CHEAP!! PM me ..
Old 05-25-2005, 09:40 PM
Confuc1ous's Avatar
I need to actually get myself a camber kit for the accord since its gotten a complete new suspension (pM sent). I took out the ground controls and the AGX's. I always heard about this washer trick but are there any down sides to it?
Old 05-25-2005, 09:59 PM
ElementMotor's Avatar
Default Re: (Confuc1ous)
I don't see why there are any downsides to it, I just did the same thing on my crx, works great. Even having extra honda bolts and washers laying around made it even better!
Old 05-25-2005, 10:05 PM
Confuc1ous's Avatar
interesting, i think if i can get a cheap camber kit then thats what im gonna use. If i cant then this bolt trick doesnt seem to tricky. I'm sure i can figure it out. The only other question i can throw out there is this, how will i know when the negative camber is no longer? Would i have to keep loosening and tightening and adding washers till its right?
Old 05-25-2005, 10:07 PM
Mr.Speed's Avatar
Default Re: (EF8 ownz U)
How does the car look after? What is the end result? Any pictures?
Thx
Old 05-26-2005, 06:12 AM
jb.
jb.'s Avatar
Default Re: (Mr.Speed)
the car has almost perfect camber, the wheels you could see are straighter, and it literally took maybe and hour start to finish plus an alignment. I did it at my friends shop so we aligned it there. Buying from advance cost me a total of $7 for everything.
Old 05-26-2005, 09:44 AM
Mr.Speed's Avatar
Default Re: (jbkiksass69)
Anyone have before and after pictures so I can see the difference?
Thanks
Old 09-27-2005, 03:30 PM
RiceRocketDave's Avatar
Old 09-27-2005, 04:17 PM
94cordlx's Avatar
Default Re: 5th gen accord rear camber washer trick guide and how to (jbkiksass69)
Any idea how many washers you would use for a 94LX lowered on H&R Sports? I've heard 2 washers for every inch dropped and others say 1 washer for 1 inch dropped. Not sure which is right. H&R Sports are supposed to be about a 1-1/2" to 1-3/4" drop.
Old 09-27-2005, 04:39 PM
asianalbutt's Avatar
so after this washer trick i dont need to get a camber for the back???
Old 09-27-2005, 05:47 PM
yardy8301's Avatar
Default Re: (asianalbutt)
correct.
Old 09-27-2005, 08:00 PM
how many washers would i need if i got a 1.75-2.00in drop in the back?
Old 09-29-2005, 04:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbkiksass69 &raquo;</TD></TR><TR><TD CLASS="quote">To start off, I did this on a 95 accord ex 4dr lowered on Apexi WS coilovers. Use at your own risk. This is a fairly easy fix for your rear camber.
Here goes:
Hope that helps everyone </TD></TR></TABLE>
wat was the drop on that accord?
Old 09-29-2005, 05:15 PM
jb.
jb.'s Avatar
Default Re: 5th gen accord rear camber washer trick guide and how to (asianalbutt)
i dont know the number of inches, i did it until it looked good, probably 2 inches. i was pulling a high 2-3 degrees of negative camber in the back
Old 09-29-2005, 05:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbkiksass69 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know the number of inches, i did it until it looked good, probably 2 inches. i was pulling a high 2-3 degrees of negative camber in the back</TD></TR></TABLE>
so about 7 washers on each bolt would do the trick??? since my car is goin to be dropped bout 1.75-2ins?
Old 09-29-2005, 05:44 PM
and since i dont have a system in the back about 5-6 washers would do the trick?? wat do u think?
Old 09-29-2005, 05:47 PM
jb.
jb.'s Avatar
that should work, just buy a package of washers and see what works. i had the benefit of doing it at a shop with an alignment rack. just dont worry too much about it, and buy more washers than you need by getting the box of them, i didnt buy them individually, return what you dont use
Old 09-29-2005, 06:11 PM
thanks been a big help
Old 07-24-2008, 09:34 AM
djkurious's Avatar
Default Re: FAQ: 5th gen accord rear camber washer trick guide and how to (jb.)
Anyone have the pictures to this trick?
Old 09-13-2008, 11:30 AM
He knows where you live!
TheMuffinMan's Avatar
Default Re: FAQ: 5th gen accord rear camber washer trick guide and how to (djkurious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djkurious &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have the pictures to this trick?</TD></TR></TABLE>
I'll be doing this tomorrow, I just got back from Advance Auto with bolts/washers. So I'll try to take pictures to rehost them.
Old 09-13-2008, 03:51 PM
gqstatus05's Avatar
Default Re: FAQ: 5th gen accord rear camber washer trick guide and how to (TheMuffinMan)
Thank you muffin, sucks when the pictures don't work.
Old 09-14-2008, 08:15 AM
Same Instructions as above, he was right on, here's some updated pictures. And some additional notes.
14mm socket (stock)
17mm socket (new)
ratchet (duh)
washers
The Parts:
The Culprits:
Bolts Out:
Comparison: (old = gold, new = black + 6 washers)
And Complete:
Difficulty Rating:
Modified by TheMuffinMan at 12:20 PM 9/14/2008
Old 09-15-2008, 04:35 AM
gqstatus05's Avatar
Default Re: (TheMuffinMan)
Good Job Muffin you just powned your CD5.
Old 10-13-2008, 07:56 PM
tpot90's Avatar
Default Re: (gqstatus05)
Is this the same procedure for a 6th gen? I am running a Sprint 2.50 in the fron & 2" in the back. Can I use washers to create negative camber on my 6th gen? If so, how many washers?
Quick Reply: 5th gen accord rear camber washer trick guide and how to
