2000 Accord V6 question...
Old 06-30-2003, 04:52 AM
mixxed's Avatar
Default 2000 Accord V6 question...
what type of gas do you use in this car??? Regular/Medium/Premium???
Old 06-30-2003, 08:52 AM
Sam Lin's Avatar
Default Re: 2000 Accord V6 question... (mixxed)
Regular.
Sam
Old 06-30-2003, 10:39 AM
mixxed's Avatar
Default Re: 2000 Accord V6 question... (Sam Lin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam Lin &raquo;</TD></TR><TR><TD CLASS="quote">Regular.
Sam</TD></TR></TABLE>
really eh?? i heard that these V6s require premium gas.....
but i know of someone who uses regular so i was curious about this..
Old 06-30-2003, 10:49 AM
YeuEmMaiMai's Avatar
if you drive a toyoya camry you need premium fuel. accord only requires regular pump gas.....
Old 06-30-2003, 11:17 AM
mixxed's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">if you drive a toyoya camry you need premium fuel. accord only requires regular pump gas.....</TD></TR></TABLE>
interesting.....
Old 06-30-2003, 06:42 PM
honda-man's Avatar
no they dont
i used regualer pumped gas it was clicking in my motor and i have a v6 honda accord. Then i put Premium in it and it has been just fine since then every time i put a reguler i have problems with my motor and it is a 2001.
Old 06-30-2003, 09:17 PM
aem01accord's Avatar
Default Re: (honda-man)
when i use reg my 4cyl knocks alittle i cant stand it.
Old 07-01-2003, 12:25 PM
iam7head's Avatar
Default Re: (aem01accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aem01accord &raquo;</TD></TR><TR><TD CLASS="quote">when i use reg my 4cyl knocks alittle i cant stand it.</TD></TR></TABLE>
It will not knock by using regular octane on 6 and4 cylinder.
read the manual and it will tell you what you need.
Old 07-01-2003, 05:36 PM
read the manul, your accord does NOT require anything but unleaded regular gas....if your car knocks on regular fuel you need to either
change gas stations
or
have the car checked out........as something is a miss with it
Old 07-02-2003, 07:36 PM
honda-man's Avatar
When i took mt honda the service depatment were i bought my honda i told them about it and they said it is eather my motor mounts or i need to put a higher octain in it so i did and it has been fine every since
Old 07-03-2003, 12:07 AM
DRFlickner's Avatar
Default Re:
The manual calls for 87 octane. I've never heard any knocking w/ 87 octane, even with the A/C on. I'd imagine you'd lose power by using a higher octane than what the manual calls for.
Old 07-03-2003, 03:10 AM
FREAKquency04's Avatar
get the supreme. if you get regular your car will work three times as hard as it should be. Plus is alittle better. but if you want your car to perform and last longer use the supreme
Old 07-03-2003, 09:26 AM
DRFlickner's Avatar
Default Re: 2000 Accord V6 question... (AcCorDH22ARaCeR)
Has anyone dyno tested 87 octane vs. 91/92 octane? I know, for example, premium does make more power in the EP3 (2002+ Civic Si), even though the manual calls for 87 octane. However, I've yet to see any dynos for the Accord V6 showing an increase in performance from using a higher octane gas.
Old 07-03-2003, 09:46 AM
iam7head's Avatar
Default Re: 2000 Accord V6 question... (DRFlickner)
I doubted but here some little something i want to share..
if you use high octane from day1 after a while your car can no longer
use lower octane because it's adapt to perform/function with the higher rating
Old 07-03-2003, 09:51 AM
ok guys they did a study at the site that used to be accordv6.com and they found that the car made LESS power on higher octane fuel....
the new site is here
http://www.v6performance.net/
the thread is here
http://www.v6performance.net/f...ctane
Old 07-07-2003, 06:13 AM
G-DASH's Avatar
When times are hard I use regular, but the majority of the time I use premium and every so often I drop in some fuel treatment just to keep things burning clean.
Old 07-07-2003, 03:41 PM
iam7head's Avatar
Default Re: 2000 Accord V6 question... (G-DASH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-DASH &raquo;</TD></TR><TR><TD CLASS="quote">When times are hard I use regular, but the majority of the time I use premium and every so often I drop in some fuel treatment just to keep things burning clean.</TD></TR></TABLE>
techron?
Old 07-07-2003, 03:51 PM
CaptainObvious's Avatar
Default Re: 2000 Accord V6 question... (iam7head)
Use mid-grade...Simple solution
Old 07-08-2003, 10:03 PM
ucb
ucb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcCorDH22ARaCeR &raquo;</TD></TR><TR><TD CLASS="quote">get the supreme. if you get regular your car will work three times as hard as it should be. Plus is alittle better. but if you want your car to perform and last longer use the supreme</TD></TR></TABLE>
this is total BS and you are talking out of your ***. Please actually know what you are talking about before you post. The accord v6 has a low compression engine, anything higher than 87 will lead to imcomplete combustion.
So you are saying imcomplete combustion is a good thing?
Old 07-08-2003, 11:15 PM
DRFlickner's Avatar
Default Re: 2000 Accord V6 question... (UCBGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCBGSR &raquo;</TD></TR><TR><TD CLASS="quote">
So you are saying imcomplete combustion is a good thing?</TD></TR></TABLE>
This is what I've been saying. Incomplete combustion is going to yield less power, and produce more emissions.
Old 07-09-2003, 09:23 PM
Doom878's Avatar
It's true. I used premium when I first got my bottle and the car drove like ****. The car tends to pull harder with regular. With the low comp you should only use regular.
woah
09-10-2008 08:52 PM
SIXPAK GQ
07-24-2007 12:16 PM
xkrntamax
07-21-2006 07:58 PM
Goofyboy
03-18-2005 01:38 AM
Vera
03-26-2004 10:49 PM
Quick Reply: 2000 Accord V6 question...
