2000 Accord F23a - Is this a plug Or Knock Sensor?
Hello. I recently replaced my motor from my 2000 Accord. The original motor was an F23a1. I purchased a JDM F23a & noticed my harness would not connect to the rear of my block. This is the last connector & was wondering, "was it ever hooked up in the first place?" I'm not to sure because my original motor looks the exact same & I feel like I overlooked it when I was removing the harness connectors to get the original motor out.
Is this some sort of plug &/or does it need to be connected? My connector from the harness does NOT look anything that will fit/work with it. All help is appreciated. Thank you.
original motor (pulled ) f23a1
new motor installed - f23a
new motor installed - f23a closeup
Re: 2000 Accord F23a - Is this a plug Or Knock Sensor?
(JON)
12-03-2003 06:05 AM
