1999 Accord rear beam compatibility
Old 04-16-2019, 04:58 PM
Icon4 1999 Accord rear beam compatibility
I am replacing the rear beam in a 1999 Accord with the 2.3 4 cyl but the replacement part is for a V6. It seems to be the same dimension wise but the rear motor mount bolt holes do not line up. Does anyone know if I can use a rear vacuum assist motor mount for a V6 model and have it match up?
Rotted 4 cyl rear beam with motor mount mounting holes
one of the mounting points of the 4 cyl rear beam
one of the mounting points of the V6 rear beam
V6 rear beam showing motor mount mounting holes
Mister Anderson is offline
Old 04-17-2019, 02:20 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: 1999 Accord rear beam compatibility
Check the part numbers on V6 and I4 cars via one of the many Honda parts websites.
They look the same, verify the V6 crossmembe has the holes you needed punched and threaded.
Just use your I4 mounts.
MAD_MIKE is offline
  • Ask a Question
Question Title:
Description:
