1993 Accord Electrical Issue (Multiple Components)
I own a 1993 Honda Accord Coupe with a manual transmission. Recently, I took the vehicle to a mechanic to replace the clutch. After replacement of the clutch, the following components no longer work:
1. Both power windows
2. Speedometer
3. Tachometer
4. Digital clock on dashboard
5. Temperature gauge
Furthermore, the following attempts have been made unsuccessfully to resolve some of the issues above:
1. Replaced the speed sensor with a new one (speedometer still not working)
2. Replaced bad brittle temperature connectors on wiring harness (temperature gauge still not working)
NOTE: I also performed the following checks
1. Checked all four 20 amp power window fuses in the fuse box under the hood. Fuses are all good.
2. Checks of the power window relay switch in the under hood fuse box indicate it is also good.
3. Checks via a test light with the ignition switch both on and off indicate NO POWER is being received by any of the four 20 amp power window fuses. Again, fuses are good - but not receiving power.
4. All other fuses in the under-hood fusebox are good and are all receiving power
Other than these issues, the car is running fine. Nonetheless, these issues are critical in numerous circumstances. The problem is, I DON'T KNOW WHAT ELSE TO DO AND THE MECHANIC IS AT A LOSS. SOMEONE PLEASE HELP! IT WOULD BE GREATLY APPRECIATED. THANKS.
2. Speedometer
3. Tachometer
Owen Pitchford
05-19-2019 08:42 AM
thekingofvtec
06-12-2018 02:29 PM
