2004 Honda Accord driver side power window not working
Hi, I have a 2004 Honda Accord ex coupe v6. Recently just the driver side power window stopped working. I replaced the window motor as well as the master power window switch. It worked fine for the first couple of days but then it stopped working again. I thought it might be the fuse so I replaced it and then it went down and up once before it stopped working again. I did the same thing again and got the same result (down, up, stop working). Any ideas on what might be causing this and how to fix it? Thank you
Re: 2004 Honda Accord driver side power window not working
If the fuse keeps blowing, then there is a short somewhere. Probably a short in the wiring near the driver's door jamb.
That makes sense but the fuse was not blown when I replaced it with another one. It was just when I put a new fuse in that the window went down and up.
Hawaii Da9
01-16-2012 06:19 AM
s4325
08-04-2010 09:31 PM
