1992 Honda Accord 198,000 miles. $850 is it a good deal?
Old 02-03-2008, 10:09 AM
WMike20052's Avatar
Default 1992 Honda Accord 198,000 miles. $850 is it a good deal?
Looked in the paper and this was in there, i called the lady and asked her if there was anything wrong with the car, she just told me to come check it out for myself. Dont know too much about Honda's but i hear there great with miles so is this worth checking out or wat?
Old 02-03-2008, 11:43 AM
steerh67's Avatar
Default Re: 1992 Honda Accord 198,000 miles. $850 is it a good deal? (WMike20052)
sounds like a good deal, but without knowing options or condition, or service records, my statement is worthless. You might be able to get the car for $850, but then you might have to sink another $500 into it to make it roadworthy.
Old 02-03-2008, 04:13 PM
awdgsx96's Avatar
Curious, where are you in NJ?
Hopefully it was garage kept. Winters in NJ aren't too kosher for our cars, especially an older one
Old 02-03-2008, 07:47 PM
WMike20052's Avatar
Default Re: 1992 Honda Accord 198,000 miles. $850 is it a good deal? (awdgsx96)
Living in Newark. But yea im not sure if she has kept it garaged or not. But what should I check out on the car before making a decision cause im a newbie when it comes to cars.
Old 02-03-2008, 09:07 PM
steerh67's Avatar
If you aren't very familiar with cars, then set up an appointment with a local garage to have them give it a once over, preferably one you have done business with in the past. If that does not sound like something you would want to do, then just check the level and color of all the fluids, tread depth on all the tires. Drive the car with the radio OFF and listen for any unusual sounds. Let the car warm up, and then listen to the engine for any strange noises or erratic idle, as well as the exhaust for any leaks. Don't be surprised if you have to put some money into the car, but for 800 bucks and a little investment you could have a reliable car. Being that the car is so old and northeast winters are rough, expect some rust over the back tires, but don't let that turn you away. If something like that matters, then you should consider saving your money for a newer car.
Old 02-04-2008, 09:27 AM
awdgsx96's Avatar
Alot of CB's and CD's also have window problems, it's covered alot on here, nothing to worry about. The motors just need replacing.
More than likely the car will have cancer on the quarter panel as mentioned, it really isn't a big deal.
Old 02-04-2008, 03:33 PM
Secret Chimp's Avatar
Run like the motherexpletiveing wind if its an automatic. The trans will poop out within 20,000 miles if it's already near 200,0000.
Old 02-10-2008, 11:48 PM
brose's Avatar
Look at the service paperwork the current owner has in her possession. Specifically focus on the timing belt and water pump replacement. With the mileage, those parts will need to be replaced again, unless she's done it recently. I own a '92 Accord with only 110K miles, and I could probably get about $1200 for it. So, $850 may not be a bad price depending on the prior maintenance records and the interior/exterior shape of the car.
Steerh67 had some good advice, so check his recommendations too.
Bottom line, take it for a test drive, with your mechanic in the pax seat to listen for noises out of the ordinary.
Good luck,
Jnolane
12-05-2012 11:30 AM
Mark
13
05-24-2012 01:22 PM
red Teggie
07-25-2011 09:59 AM
Formula52
21
12-30-2007 11:33 PM
Bulli Kid
11-08-2007 01:13 PM
Quick Reply: 1992 Honda Accord 198,000 miles. $850 is it a good deal?
