1991 accord lx TPS specs?
Old 03-15-2011, 05:57 PM
portlandkidd157's Avatar
Default 1991 accord lx TPS specs?
I need the specs/ correct adjustment for the TPS Sensor? The paper that was with the part stated that:
I needed to volt test the 2nd and 3rd connector, by piercing through the wires on the TPS connector.
It says:
0.5volts when the throttle body is closed.
4.5volts when the throttle bosy is fully open.
I did this and i got 4volts when closed, and 1 when open. No adjustments changed these readings..
I then watched a video and a guy said you check the OHMs between the 1st and 2nd wires, or bottom two.. and the reading should be between
.5000-.9000 Ohms.
Does anyone know what is correct? where do i find adjustment info?
1991 accord lx 2.2L
Old 03-15-2011, 07:18 PM
GhostAccord's Avatar
Default Re: 1991 accord lx TPS specs?
IIRC you need to pre-load the TPS sensor (rotate the TPS shaft 180) before you put it into the throttle body. The two wires that you are probing should be the signal wire (+ RED/BLK??) and the ground wire (- GRN/WHT??).
The specs are approx. 0.45v - 0.5v closed throttle and 4.5v - 5v wide open throttle. I've never used resistance so I'm not sure what the specs are using that test procedure.
PenIsland
10-25-2014 06:48 PM
saviour250
03-14-2009 03:42 PM
92prelude23
01-26-2009 05:43 PM
turbod16y7vtec
07-02-2002 07:23 AM
Quick Reply: 1991 accord lx TPS specs?
