Jdm b18c itr 96-00swap for civic
I'm looking to sell my JDM B18C out of my 96 EK. It comes with everything but the motor mounts, but you can do the swap using your stock mounts.
I only put about 8k miles on the motor since I swapped it in last year. I got motor from Hmotorsonline.
Here are the specs:
96-97 jdm b18c wit LSD tranny and ECU.
* Oil changed every 3 months, same with the tranny oil
* New Exedy clutch and resurfaced Type-R flywheel
* Arp flywheel bolts
* MSD spark plug wires
* Engine harness redone by rywire.
* Spoon Sports fan switch
* Spoon Sports thermostat
* CTR n1 crank pully and new belt
* DC Sports Type-R 4-1 Race Header
* AEM Cold Air Intake
* Custom test pipe
* Si linkage
* si axles
* Rear Si tranny bracket
* Si driver side bracket
I also replaced these gaskets before swapping the motor in:
* Oilpan gasket
* Intake manifold gasket
* Exhaust manifold gasket
* Valve cover gasket
* Throttle body gasket
* vTEC solenoid gasket
I will also include these parts on the side (All OEM Honda):
* Head gasket
* Cam seals
* Valve seals
* Front main seal
* Oil seal
* Cylinder head seal
* Cylinder head plug
It also has a new water pump, timing belt, and tensioner.
To those that are interested, I can start the car up for you.
When I get a buyer, I will pull motor out. I am looking for $4500 FIRM
I will NOT part out anything.
Motor on Kauai Willing ship any island if buyer pays for shipping cost
Here are the specs:
* Custom test pipe
* Si linkage
* si axles
* Oilpan gasket
* Head gasket
* Cam seals
* Valve seals
* Front main seal
* Oil seal
95integragsr1984
24
01-11-2003 02:28 PM
