Originally Posted by Scotty Dosent Know
You can get Recaro SPG in an XL version, the XL is some thing like 35mm wider
<--#nohomo haha
ditto on the zip ties. i used them..often..and never had such a problem that bad. do you have that white grommet in there still? if so try taking that out.
Yeah they're useless. OEM hardware on that department lacked big time. Use better hardware or zip ties. Thats definitely an issue I want to address sooner or later. I would like for there to be something that I can take out and reuse and be easy to take out and of course have flawless fitment.
I have a pet peeve about rattles, so my interior is bolted together with as much torque as possible. My bumper is held on by a long 10mm bolt, two washers and a nylon locking nut on each side. I've also found if you bend the tab on the inside of the fender up as much as possible it helps keep the gap tight.
