DA Integra's Only
Old Feb 29, 2008 | 04:40 AM
  #23076
Mattyg2's Avatar
i think i have the dirtiest car right now
Old Feb 29, 2008 | 04:47 AM
  #23077
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: (Mattyg2)
NEED HELP FELLAS!
Rad fan wont turn on.
Heres whats up. Finally got the car running again after sitting for 6 months. Thermostat was stuck so it neeed to be replaced. I took that excuse to order a new radiator and fan. Last night I installed the fan and radiator. I cut the stock Fan plug and wired that into the new slim fan. I got everything in and let the air out, in all that time the fan didn't turn on.
I then tested the fuses, relay, wires, everything power related. The fan does come on when hooked to like a jumper so its not that. The thing that makes me wonder is my temp gauge does not work and has not worked for years, would that affect the fan coming on?
I let it run for about 20 minutes inside and the fan didn't come on. I think tonight I will take it for a spin and see if the kicks the fan on. I am also gonna hook up hondata and set the fan to stay on and see if that works to eliminate and wiring/sensor problems. Hondata hasn't worked on my laptop since I reimaged it so hopefully it co-operates with me tonight.
I have heard so many different opinions about wiring the fan to always stay on. What is everyone's input on the topic. I mean I like in MD and it does get kinda hot in the summer and kinda cold in the winter.
Thanks! Friday
Modified by Mattb16teg at 3:55 PM 2/29/2008
Old Feb 29, 2008 | 07:24 AM
  #23078
tegboi's Avatar
if the fan comes on if you jump the jumper wires at the switch. but overheats, then the sensor is bad.
i've had my fan rewired several times, in several different configurations.
direct power & ground and a switch on the power, direct ground, with a switched power when key is on, then those setups always ran sketchy, and scary because there was no relay in the system for it.
then i added in a relay, and a switch inside the car, from there the wires stopped getting hot, was more dependable, but wasnt great, because i still had to switch it on and off. so i finally wired back in the sensor for the switch, with the rest of my stand alone relay & fuse setup.
so pretty much, i made a big mess, and have wires showing, vs keeping the original wiring, and finding out what was wrong..
it all started when i removed AC & the condensor fan. then i started the overheating problem.
Old Feb 29, 2008 | 07:25 AM
  #23079
jkeno112's Avatar
Default Re: (Mattb16teg)
Bad Fan Switch??? Try that if not... its probably too Cold in Ur Area to have the fan kick on. Correct me if i am wrong but the fans will only kick on when the engine reaches a certain temperature. And having a busted or nonworking temp gauge is kinda not helping your situation.
I am happen to run my fans constantly on and i have 2 10" slim fans both pushing air towards the block instead of pulling air out. I have no problems whatsoever with running the fans the way i do.
Old Feb 29, 2008 | 08:27 AM
  #23080
Mattb16teg's Avatar
Community Builder
Default Re: (jkeno112)
Right now im leaning towards running it constantly. I will either wire it to the ignition or some power source OR program it to always be on through Hondata.
I think it is cold for the fan to kick on, thats why Im gonna go drive it and check the fan.
The Temp gauge has not worked for like 3 years, 2 motors and 2 clusters but the fan has. So I am not to worried about that yet.
Arg why do I love this thing so much!
Thanks for some feedback fellas
Old Feb 29, 2008 | 08:28 AM
  #23081
J's 94 Accord's Avatar
This is the last year, I'm going to play around with the DA.
Old Feb 29, 2008 | 08:31 AM
  #23082
MaltBeer's Avatar
Default Re: (J's 94 Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J’s 94 Accord &raquo;</TD></TR><TR><TD CLASS="quote">This is the last year, I'm going to play around with the DA.
Old Feb 29, 2008 | 08:32 AM
  #23083
jkeno112's Avatar
hmmm i wonder why????
  #23084
super jdm yo's Avatar
what?!
Old Feb 29, 2008 | 08:53 AM
  #23085
Default Re: (MaltBeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaltBeer &raquo;</TD></TR><TR><TD CLASS="quote">
No bull..
Old Feb 29, 2008 | 08:56 AM
  #23086
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jkeno112 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm i wonder why???? </TD></TR></TABLE>
do YOU know why?
Old Feb 29, 2008 | 01:19 PM
  #23087
Brice.Hayden's Avatar
do YOU know why? </TD></TR></TABLE>
I wanna know!
Old Feb 29, 2008 | 02:03 PM
  #23088
Mattyg2's Avatar
i want to know also???
Old Feb 29, 2008 | 02:05 PM
  #23089
Mattyg2's Avatar
i had to give some vtak to my brother who once had some vtaK!!!
Old Feb 29, 2008 | 02:58 PM
  #23090
91 crx savage's Avatar
I had my fan switch replaced and went bad again so I just wired it to a switch and use it every now and then not much at all though only when im stuck in traffic..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattb16teg &raquo;</TD></TR><TR><TD CLASS="quote">Right now im leaning towards running it constantly. I will either wire it to the ignition or some power source OR program it to always be on through Hondata.
Thanks for some feedback fellas </TD></TR></TABLE>
Old Feb 29, 2008 | 03:45 PM
  #23091
sikciv666's Avatar
Default Re: (91 crx savage)
wtb captiva blue DA!!!!
Old Feb 29, 2008 | 03:50 PM
  #23092
RenzoDaPlayboi's Avatar
Default Re: (sikciv666)
i will have updates on my 5 speed conversion tomorrow...so check the thread in my sig...thanks
Old Feb 29, 2008 | 04:35 PM
  #23093
1200 Hobos's Avatar
Default Re: (RenzoDaPlayboi)
Anyone want a pair of 6.5" speakers practically for free considereing their quality?
$40+shipping.
These only fit in the rear but you could fit them in the front with 1" spacers (the magnets are 3" deep). Good speakers here for cheap.
Old Feb 29, 2008 | 04:54 PM
  #23094
kiDchaos's Avatar
p.s. buy my truck!!
http://www.vadriven.com/forums...27151
p.s.s. buy my gs-r
http://s92.photobucket.com/alb...6.pbw
Old Feb 29, 2008 | 04:56 PM
  #23095
BUILT_DC2's Avatar
Default Re: (kiDchaos)
bump for Da's
Old Feb 29, 2008 | 05:01 PM
  #23096
Default Re: (BUILT_DC2)
^^^^Clean
Old Feb 29, 2008 | 05:04 PM
  #23097
sinfulDB1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenzoDaPlayboi &raquo;</TD></TR><TR><TD CLASS="quote">^^^^Clean</TD></TR></TABLE>
thats a real nice color
Old Feb 29, 2008 | 10:55 PM
  #23098
Mattyg2's Avatar
random pic
Old Feb 29, 2008 | 11:03 PM
  #23099
Ol'SkoolDA9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiDchaos &raquo;</TD></TR><TR><TD CLASS="quote">
horizon grey...oh how I love you RP-21M
Old Feb 29, 2008 | 11:36 PM
  #23100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattyg2 &raquo;</TD></TR><TR><TD CLASS="quote">random pic
Size:  93.4 KB</TD></TR></TABLE>
randomly stupid
