DA Integra's Only
Old Feb 8, 2007 | 10:31 PM
  #12426
sixfiveoh's Avatar
Sweet Title
Default Re: (Lewy. Dee Ayy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewy. Dee Ayy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.g2ic.com/forums/showthread.php?t=45879 boom.
did them on my car..took me 2 min's..
anyone running Ksports on there DA..i found a GREAT deal on ksports..how do you like them?</TD></TR></TABLE>
yee! thanks.
I'm running em. Didn't like em at first, but now that they're broken in, they feel great. Really surprised since I got them SO cheap, they're not as nice as my Tein HAs, but cmon, you cant compare that.
One mistake I made was slamming it and riding on the softest setting for the longest time, as soon as I put it on stiffest, it made a world of difference.
These things dump you LOW, but keep the preload, it rides like **** without it. I take my car in the mountains alot, and it definitely hangs with the WRXs I go with
Old Feb 8, 2007 | 10:43 PM
  #12427
Lewy. Dee Ayy's Avatar
Default Re: (sixfiveoh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixfiveoh &raquo;</TD></TR><TR><TD CLASS="quote">yee! thanks.
These things dump you LOW, but keep the preload, it rides like **** without it. I take my car in the mountains alot, and it definitely hangs with the WRXs I go with </TD></TR></TABLE>
thats what i like to hear..but where im from..the biggest turns we have are on/off ramps lol what spring rates are u running..i was thinkin 12k front 9k rear i like a stiff ride but not bouncy. and i dont want to scrape on every bump.
EDIT: and what do you mean by preload?
Old Feb 8, 2007 | 11:02 PM
  #12428
sixfiveoh's Avatar
Sweet Title
EDIT: and what do you mean by preload?</TD></TR></TABLE>
I'm running on the shelf rates, not sure what they are, I bought them used with a couple hundred miles off a guy on here... It's a nice stiff ride, nothing ridiculously bouncy at all.
Just dont go too low, and you wont scrape on everything. I'm as low as I can go in the front while maintaining the preload. If you don't keep the preload, you can go lower, but like I said before, it rides shitty.
Preload is one of those things that alot of people will tell you doesn't matter, and I used to be with them. Until I decided to lower my car more in the front and break the preload. Now I am a firm believer that if you want the most out of your suspension, KEEP THE PRELOAD.
Basically what preload is, is keeping the spring snug between the two lower perches and top of the coilover, so it has no room to play, while there is no load on the car (while it is still in the air). Only use the bottom most perch to adjust height. Here, lemme see if I can find a picture to illustrate it...
In other words, the 2 adjustable perches that are snug up against the spring should be tightened together and stay snug up against the spring, so theres no room for play. The lower perch is at it's lowest setting right now, so if those were on your car like that, that's as low as it would go without losing your preload.
You'll find countless threads on H-T with arguments on whether preload is necessary or not, some say it isn't, some say to even go as far as to tighten the top nut as well as tightening the perches up to the spring.
Anyways. Yeah.
Old Feb 8, 2007 | 11:20 PM
  #12429
thanks for the info. i had a feeling it was something like that i just wasent to sure. and i think off the shelf they are 12k front 7k rear btw. cant wait!! bahhh lol.
Old Feb 8, 2007 | 11:55 PM
  #12430
ProjectJDM's Avatar
sixfiveoh- got any pics of lowest the DA can go while still keeping the preload?
Old Feb 9, 2007 | 03:57 AM
  #12431
608 Gangsta's Avatar
Default Re: (ProjectJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectJDM &raquo;</TD></TR><TR><TD CLASS="quote">sixfiveoh- got any pics of lowest the DA can go while still keeping the preload?
prolly not the lowest but heres mine im pre-loaded
Old Feb 9, 2007 | 06:40 AM
  #12432
...:::MaRk:::...'s Avatar
Default Re: (608 Gangsta)
^^^ so fresh
Old Feb 9, 2007 | 07:22 AM
  #12433
Rosetta Stoned's Avatar
Default Re: (dominicanoda9)
Where can you find these great deals on ksports?
Old Feb 9, 2007 | 08:20 AM
  #12434
Nevets's Avatar
Default Re: (Rosetta Stoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosetta Stoned &raquo;</TD></TR><TR><TD CLASS="quote">Where can you find these great deals on ksports? </TD></TR></TABLE>
JLBMotorsports
Old Feb 9, 2007 | 08:32 AM
  #12435
VDo's Avatar
VDo
Default Re: (Nevets)
Does anyone have pics of how/if they installed the extra hardware pictured below that came with their Ksports. I'm guessing they're for securing the front brake lines, but not sure. And also, were you guys able to keep the adjustment ***** in place while driving or does it interfere with the hood? TIA.
Old Feb 9, 2007 | 09:28 AM
  #12436
DA is best's Avatar
thanks sixfiveoh for the littlw write up on preload, because my coilovers have alot of play so now i will adjust them up so now i dont have to ride around like im in a lowrider on hidrolics
Old Feb 9, 2007 | 10:26 AM
  #12437
sixfiveoh's Avatar
Sweet Title
Default Re: (DA is best)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA is best &raquo;</TD></TR><TR><TD CLASS="quote">thanks sixfiveoh for the littlw write up on preload, because my coilovers have alot of play so now i will adjust them up so now i dont have to ride around like im in a lowrider on hidrolics</TD></TR></TABLE>
This is as low as I can go in the front while keeping the preload. The back has alot more room to go down tho... weird how that works. Oh yeah, this was before rims and cut and polish on my paint.
and when I went really far down, and undid the preload
Old Feb 9, 2007 | 10:53 AM
  #12438
DA9Rood's Avatar
anybody know if there is a Turbo setup that fits a DA with a full size Koyo radiator, i dont want to get a half size?
Old Feb 9, 2007 | 12:42 PM
  #12439
92NoTeC's Avatar
Default Re: (DA9Rood)
Sounds like you need to read this for starters:
G2IC Turbo Guide
Old Feb 9, 2007 | 01:44 PM
  #12440
allnapower's Avatar
Default Re: (92NoTeC)
hey guys, got a quick question will EG lowering springs fit on a DA?
Old Feb 9, 2007 | 04:08 PM
  #12441
Brice.Hayden's Avatar
Default Re: (allnapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnapower &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, got a quick question will EG lowering springs fit on a DA?</TD></TR></TABLE>
read a few pages back and there is a whole discussion on suspension...so no it wont fit without changing parts around....something about a spork
Old Feb 9, 2007 | 04:13 PM
  #12442
DATZ WEAKSAUCE's Avatar
Default Re: (JasperDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasperDA9 &raquo;</TD></TR><TR><TD CLASS="quote">read a few pages back and there is a whole discussion on suspension...so no it wont fit without changing parts around....something about a spork</TD></TR></TABLE>
it will fit u only need to change out the fork if you use dc/eg shocks
Old Feb 9, 2007 | 05:35 PM
  #12443
THE *FOB* MOB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 608 Gangsta &raquo;</TD></TR><TR><TD CLASS="quote">
Size:  64.7 KB</TD></TR></TABLE>
nice
Old Feb 9, 2007 | 06:52 PM
  #12444
DA9_DAD's Avatar
Default Re: (THE *FOB* MOB)
I know this isn't the DA squad area but
Welcome me, DAMN IT!
I just bought this a few DA's ago and I love it. This weekend I'll be throwing my Omni Sleeves and KYB's taking it about 2.25" I don't want to slam it I just want a nice stance. Also completing the brake upgrade to all around slot and cross drilled Brembo's.
Old Feb 9, 2007 | 06:59 PM
  #12445
DA9_DAD's Avatar
I'll be puting my EG forks with KYB AGX's in front and KYB GR-2's in back. sitting on Omni Power Sleeves.
Old Feb 9, 2007 | 09:49 PM
  #12446
~sp33~'s Avatar
EFB055
Default Re: (FR33K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR33K &raquo;</TD></TR><TR><TD CLASS="quote"> (which you cant get in australia )</TD></TR></TABLE>
Good to have aussies on the site
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAnthony9 &raquo;</TD></TR><TR><TD CLASS="quote">I know this isn't the DA squad area but
Welcome me, DAMN IT!</TD></TR></TABLE>
DONT LISTEN TO HIM... Then he might bring his hot sedan back to the ef sedan squad.
Old Feb 9, 2007 | 10:30 PM
  #12447
dohctor_B's Avatar
Default Re: (DAnthony9)
I'll be puting my EG forks with KYB AGX's in front and KYB GR-2's in back. sitting on Omni Power Sleeves.</TD></TR></TABLE>
So your saying all you need is the forks? cuz thankfully i still have the forks from a civic i parted out.
Old Feb 9, 2007 | 10:31 PM
  #12448
ErMaK's Avatar
looks similar to my old 90 DA
Old Feb 10, 2007 | 01:04 AM
  #12449
Frisco-EG6's Avatar
Default Re: (ErMaK)
i just picked this up about a month ago.
Old Feb 10, 2007 | 02:44 AM
  #12450
Jose-aka-Pedro's Avatar
Default Re: (Frisco-EG6)
Looks good ^^
thats what mine looked like when i got it. Just not lowerd.
And now my da looks like this. To Highschool salary.
DA bump, #288 checkin in.
Im thinking an H22 swap is in its future.
I love my DA.
