DA Integra's Only
Old Jan 23, 2007 | 09:57 PM
  #11976
MR_FIX_IT's Avatar
Default Re: (da9pwnsu)
^^^fat fives look dope.............lovin the car
Old Jan 23, 2007 | 10:40 PM
  #11977
JDMkidMARC's Avatar
SOMEONE BUY MY DA NOW!!!!!!!!!!!!!!!!
$4000 obo!!!!!!!!!!!!!!!!
Located in So Cal!!!!!!!!!!!!!!!!!
Old Jan 23, 2007 | 11:32 PM
  #11978
da9wonder's Avatar
Default Re: (JasperDA9)
what do u do.... open up the taillight? is there a thread about this? please help have no time right now
Old Jan 23, 2007 | 11:33 PM
  #11979
aladosis's Avatar
Default Re: (crxwonder)
woops went on the wrong account AHHA
Old Jan 23, 2007 | 11:38 PM
  #11980
da9pwnsu's Avatar
Default Re: (da9wonder)
u kno u dont need multiple accts rite, u can just change ur name etc
Old Jan 23, 2007 | 11:39 PM
  #11981
ErMaK's Avatar
Default Re: (DENCIO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Sick
Old Jan 24, 2007 | 06:04 AM
  #11982
GRANT!'s Avatar
Default Re: (ErMaK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ErMaK &raquo;</TD></TR><TR><TD CLASS="quote">
Sick </TD></TR></TABLE>
that IS sick!
Old Jan 24, 2007 | 08:37 AM
  #11983
1badda's Avatar
K fellas heres the situation. My girl was driving my da one night and hit a manhole.(let me remind you that my car is dropped) THe manhole did some damage to my crossmember. I mean it was bad, you let go of the steering wheel and the whole car goes the right real hard. But anyway changed crossmember and did an aligment and i noticed that the axles and lower control arm are not straight. As if there leaning back some. You think she fucked up the whole k frame??
Old Jan 24, 2007 | 08:49 AM
  #11984
ChaseIntegra's Avatar
Default Re: (608 Gangsta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 608 Gangsta &raquo;</TD></TR><TR><TD CLASS="quote">
just throw some washers back there.. if that dont work get a camber kit
thats what i did : )
dey mo flush yo! </TD></TR></TABLE>
He's not talking about camber in the rear, he's talking about making the wheels sit more flush with the fenders, as in using wheel spacers like he mentioned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixfiveoh &raquo;</TD></TR><TR><TD CLASS="quote">
I'm thinking of getting some spacers to make the wheels a little more flush?
Those wheels probably have a +40-42 offset if i'm not mistaken. You can get a 5mm, 10mm, 15mm, and a 20mm spacer from H&R, and I know there are different sizes out there available also just check around. Just take the offset of your wheels (ex +42) and subtract the thickness of the spacer you wanna use (ex 15mm) , ie 42-15=27 and that will be your new offset with those spacers. Most come with but if they don't you'll need extended wheel studs installed to accomodate the spacers. I say get some and hook it up, you won't be disappointed!
Old Jan 24, 2007 | 08:55 AM
  #11985
Dee A Nine's Avatar
Default Re: (1badda)
1badda - Ooohhhh dang, possibly dude... possibly.
Old Jan 24, 2007 | 09:38 AM
  #11986
1badda's Avatar
Damn that sucks. ANybody got a spare k frame??
Old Jan 24, 2007 | 09:41 AM
  #11987
Hella Hyphy DA's Avatar
go have it checced out if anything...just so ur 100% sure
Old Jan 24, 2007 | 11:35 AM
  #11988
Brice.Hayden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxwonder &raquo;</TD></TR><TR><TD CLASS="quote">what do u do.... open up the taillight? is there a thread about this? please help have no time right now</TD></TR></TABLE>
yeah there was one on g2ic...but its not hard....take the tail light off the car....remove the bulbs and pour like a 1/4 cup hot water a 1/4 cup of super clean and siwsh around till all the pink lines turn white then keep out till it dries.
Old Jan 24, 2007 | 01:27 PM
  #11989
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: (JDMkidMARC)
if a jack doesn't fit under your car just drive over 2 bricks so it raises the car about 2 inches.. then the jack should fit under the car no problem..
Old Jan 24, 2007 | 03:18 PM
  #11990
J's 94 Accord's Avatar
Default Re: (ohsnapzafingcu)
got scammed....
anyone in OHio that can help out?
https://honda-tech.com/zero...74238
Old Jan 24, 2007 | 03:45 PM
  #11991
92LSVTEC's Avatar
https://honda-tech.com/zerothread?id=1872128
Old Jan 24, 2007 | 06:22 PM
  #11992
sixfiveoh's Avatar
Sweet Title
Default Re: (ChaseIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Those wheels probably have a +40-42 offset if i'm not mistaken. You can get a 5mm, 10mm, 15mm, and a 20mm spacer from H&R, and I know there are different sizes out there available also just check around. Just take the offset of your wheels (ex +42) and subtract the thickness of the spacer you wanna use (ex 15mm) , ie 42-15=27 and that will be your new offset with those spacers. Most come with but if they don't you'll need extended wheel studs installed to accomodate the spacers. I say get some and hook it up, you won't be disappointed!</TD></TR></TABLE>
You got it, those are 42s.
If I went with 15mm spacers creating a 27mm offset, would that look ridiculous? What's a decent offset on DAs? I'm guessing somewhere around 32?
If I do that, should I run maybe a 5mm spacer on the front as well to keep things balanced?
Old Jan 24, 2007 | 06:33 PM
  #11993
Default Re: (sixfiveoh)
my mechanic uses 10mm spacers on his ssr comps so he can clear his KVR calipers. they look fine on there. thats as much as i would go without extended studs
Old Jan 24, 2007 | 06:45 PM
  #11994
1badda's Avatar
Anyway possible to put a non sterring rack on our da from a rex??
Old Jan 24, 2007 | 08:21 PM
  #11995
Jose-aka-Pedro's Avatar
Hey guys!
#288 bumpin this shiet with a video!
My friends GSR Swapped DA.
About to be swapped for a poor mans type r.
Well check out the video! and the rest of mine!
http://vids.myspace.com/index....04275
Old Jan 24, 2007 | 08:30 PM
  #11996
EJ_ALLMOTA's Avatar
my homies DA, just to keep the pics part going..
  #11997
Lewy. Dee Ayy's Avatar
Default Re: (Jose-aka-Pedro)
anyone ever tried to put miata rim's on a DA? do they clear the calipers? i had some on my EG hatch and some dumb bitch hit me so i want to see if they will fit on my new DA i think they should look sick.
the rims &lt;.
Old Jan 24, 2007 | 08:36 PM
  #11998
Default Re: (Lewy.)
pics of DA or die...
Old Jan 24, 2007 | 09:23 PM
  #11999
Dee A Nine's Avatar
Default Re: (Lewy.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewy. &raquo;</TD></TR><TR><TD CLASS="quote">anyone ever tried to put miata rim's on a DA? do they clear the calipers? i had some on my EG hatch and some dumb bitch hit me so i want to see if they will fit on my new DA i think they should look sick.
the rims &lt;.</TD></TR></TABLE>
Tried it, doesn't fit. Doesn't clear the brake calipers unless you get spacers...
Old Jan 24, 2007 | 09:35 PM
  #12000
Default Re: (Dee A Nine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee A Nine &raquo;</TD></TR><TR><TD CLASS="quote">Tried it, doesn't fit. Doesn't clear the brake calipers unless you get spacers...</TD></TR></TABLE> man thats shitty..how bad did it hit? like to much to just shave the caliper a little?
