DA Integra's Only
Old Sep 15, 2004 | 01:56 PM
  #701
rastropovitch
Guest
Posts: n/a
Default Re: (tightE46)
Hows that silver bullet bimmer been running???
Old Sep 15, 2004 | 01:57 PM
  #702
tightDA8's Avatar
Default Re: (MSchu)
same...changed the body kit...went full hamann...but now i have this old school accord to fix up....Cant leave my honda roots alone..............
Old Sep 15, 2004 | 02:04 PM
  #703
rastropovitch
Guest
Posts: n/a
Default Re: DA Integra's Only (xtrac1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtrac1 &raquo;</TD></TR><TR><TD CLASS="quote">
I've seen the Place Racing crossmember and its a nice piece. It looks a lot lighter than the factory unit. But under HEAVY braking, it seems it might flex a little. I think most of the braking load is transfered into the front trailing arms/crossmember. If I do decide to use it, I might have to beef it up a bit. Whats your opinion on the crossmember and do they still sell it?
IMO, braking is more important than power/handling for a road racer and I didn't want to compromise the braking performance. It should be Ok for a street car that will visit the track once in a while. I may be completely wrong but I'm gonna go with gut instinct </TD></TR></TABLE>
I'm not really sure this made sense, The OPM spherical bearing kit was developed with full time road racing in mind. I think the weekend tracker would be a hard bushing kit. The placeracing X member/ OPM bearing kit is an excellent addition to a track car. You would be surprised at the room it affords in the front of your DA, you should have come to some of our so cal DA/DB2 meets to see some in person. How have you addressed the high weight bias that is associated with such a huge swap? the 18 swap is a more friendly in as far as the weight distribution, but the H's are big motors. This does not effect drag car as much as a road race car.
Old Sep 15, 2004 | 03:55 PM
  #704
xtrac1's Avatar
rookn00b
Default Re: DA Integra's Only (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not really sure this made sense, The OPM spherical bearing kit was developed with full time road racing in mind. I think the weekend tracker would be a hard bushing kit. The placeracing X member/ OPM bearing kit is an excellent addition to a track car. You would be surprised at the room it affords in the front of your DA, you should have come to some of our so cal DA/DB2 meets to see some in person. How have you addressed the high weight bias that is associated with such a huge swap? the 18 swap is a more friendly in as far as the weight distribution, but the H's are big motors. This does not effect drag car as much as a road race car.</TD></TR></TABLE>
Im not questioning the bearing kit. My main concern was the strength of the Place Racing crossmember. I haven't seen them upclose, only pictures. I've seen the extra room they provide, but it just doesn't seem strong enough to take the load from extreme braking. If they are still available, I might pick one up and modify it to make it stronger.
As far as the weight distribution, I'm doing whatever I can to take out the weight up front. Since the car is being built strictly for road racing, I've removed the front bumper, headlights, ac/heater/cruise, etc.........
The brakes I plan on using will require a different master cylinder. I will install a Tilton pedal set, extend the steering shaft and move the seat back as far as I can(touring car style).
This car was a street car project about 7-8 years ago. If I was building a DA track car from scratch, I would not have chosen the H22. Since my car was already setup for the H22, I didn't want to redo everything to accept a B-series.
Old Sep 16, 2004 | 07:40 AM
  #705
rastropovitch
Guest
Posts: n/a
Well it looks like your on your way to a great car, be sure to bring her to our meets in the future. The only reason I had commented on the h engine is because the front to rear weight bias that will occur with that engine... but until it's built you never know, you may be able to dial out the effects using suspension/tire pressure set up. Almost certainly any after market cross member will be less stiff than the OEM, but they save you weight and are adjustible for caster(different track set ups)...
Old Sep 16, 2004 | 02:29 PM
  #706
skunkintegra's Avatar
Here's my DA wearing a set of my buddies blades!
Modified by skunkintegra at 6:17 AM 9/21/2004
Old Sep 16, 2004 | 05:06 PM
  #707
SirEm1's Avatar
Default Re: (JDMprojects)
Tight Whip!!
Old Sep 16, 2004 | 05:44 PM
  #708
JDM2ndGen's Avatar
Default Re: (SirEm1)
clean DA? ...whats the setup or is it stock ?
Old Sep 17, 2004 | 12:02 AM
  #709
Amkread's Avatar
Default Re: (MSchu)
upppp for the scene's OG..
Old Sep 17, 2004 | 01:31 AM
  #710
jdmintegraxsi's Avatar
Default Re:
Old Sep 17, 2004 | 07:28 AM
  #711
SactownXSi's Avatar
Default Re: Re: (jdmintegraxsi)
Good looking Car there man
I like!
-Nick
Old Sep 17, 2004 | 08:37 AM
  #712
GSaargh's Avatar
Default Re: (MSchu)
msteggy and backintheda...
mad props to you 2
Old Sep 17, 2004 | 08:55 AM
  #713
H.A.R.T B18C1EG6's Avatar
Old Sep 17, 2004 | 04:44 PM
  #714
JDM2ndGen's Avatar
Default Re: Re: (H.A.R.T B16AEG6)
^hottness .... ^
Old Sep 18, 2004 | 06:53 AM
  #715
BACKintheDA's Avatar
Default Re: (GSaargh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSaargh &raquo;</TD></TR><TR><TD CLASS="quote">msteggy and backintheda...
mad props to you 2 </TD></TR></TABLE>
Thanks man
Old Sep 18, 2004 | 07:42 AM
  #716
Speedz's Avatar
Default Re: (BACKintheDA)
here's my buddy's 92 (left) and my 93
he's got lsvtec, i got poor mans ITR
Old Sep 18, 2004 | 08:38 AM
  #717
evil_s13's Avatar
damn there are alot of nice DA's on this...to bad mine doesnt look that nice...well here it is. hope you like
Old Sep 18, 2004 | 01:22 PM
  #718
akb16's Avatar
Default Re: (evil_s13)
where is the rest of the kit?
Old Sep 18, 2004 | 01:27 PM
  #719
DSRxSALSA's Avatar
Default my car
sparco nsII's !!
Old Sep 18, 2004 | 01:28 PM
  #720
A.E Motoring's Avatar
Default Re: DA Integra's Only (bergenholtzracing)
good luck with your project dood...nice come up
Old Sep 18, 2004 | 03:50 PM
  #721
The Destroyer's Avatar
Default Re: DA Integra's Only (JDM BoI)
Just stating my opinion, I dont like the way the Mugen kit looks on DA's.
Old Sep 18, 2004 | 04:59 PM
  #722
djsbon's Avatar
steelies rock!
Old Sep 18, 2004 | 05:54 PM
  #723
JDM2ndGen's Avatar
Default Re: my car (92integGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integGS &raquo;</TD></TR><TR><TD CLASS="quote">
sparco nsII's !! </TD></TR></TABLE>clean DA ...how do you get the fogs to stay on without having the headlights on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil_s13 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>what suspension are you running ...your DA look dumped :up:
Old Sep 18, 2004 | 06:51 PM
  #724
gtfour43's Avatar
Default Re: my car (JDM2ndGen)
Bump
Couple of my POS
Old Sep 18, 2004 | 08:05 PM
  #725
Default Re: my car (gtfour43)
Can you get a better front shot, i like those corners.
