BUILT NOT BOUGHT!
Old Jan 21, 2011 | 02:37 PM
  #2226
NastyDB8's Avatar
Default Re: BUILT NOT BOUGHT!
Originally Posted by 91sedan_kid
100% correct.
PHOTW!
  #2227
lude72's Avatar
it kinda sounds like won-ton soup
Old Jan 21, 2011 | 02:46 PM
  #2228
NastyDB8's Avatar
Noodles are different I am gonna guess kinda like rice noodles very long and not too thick noodle do I dare say similar to spaghetti except it white in color, definately a different taste than wonton soup
Old Jan 21, 2011 | 02:50 PM
  #2229
lude72's Avatar
cool
Old Jan 21, 2011 | 02:56 PM
  #2230
lude72's Avatar
running from the sun in the teg (took with phone at 60mph)
Old Jan 21, 2011 | 02:58 PM
  #2231
lude72's Avatar
need some miles ? i got some to spare......
Old Jan 21, 2011 | 03:11 PM
  #2232
NastyDB8's Avatar
DAAAAAAMN!! been around the world..... lol
Old Jan 21, 2011 | 03:15 PM
  #2233
lude72's Avatar
its on its 2nd motor and i also swapped it from auto to 5 speed but the first motor went 308,xxx
Old Jan 21, 2011 | 05:02 PM
  #2234
mugendamugen's Avatar
If you are looking for a font for the stickers look here there are thousands of them
http://www.dafont.com/ hope this helps you ...............................the car show you speak of post the info me an some of the guys might go depends on when it is...........................any one here from the sac area? as there is a da meet this sunday if you like to pop up there
Old Jan 21, 2011 | 05:06 PM
  #2235
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Hi guys, I'll be posting my car info in a bit, it's definitely built, I try not to buy anything at all, as I do all my own work and fabricating, the only thing other people do for me, is I have friends who are expert welders, I do the fabricating and they weld what I fabricate together. I do my own wiring, plumbing, upholstery, paint and body, exhaust work, suspension, engine, mods and pretty much everything else. I can't stand other people working on my stuff anyway. I have a 1986 Accord, I've owned it for over 11 years, it's been down the last three for extensive modifications, including a custom intake manifold with dual SU's, a complex electrical system modification, more interior mods, and I'm in the middle of putting in a new 2 inch stainless exhaust with side exit dual tips, and an S&S 4-1 header, an MSD 6-t with GM blaster coil, delta cam, bisimoto valve springs, and about 300 other mods, literally.
Old Jan 21, 2011 | 05:13 PM
  #2236
91_LS's Avatar
Was up crew,i just got back from helping another DA owner,his coil went out and so we went to pick and pull and found out that the first gen tegs have the same dizzy and parts inside of it. We swapped the parts and car started right up.
Old Jan 21, 2011 | 05:24 PM
  #2237
crx civic 88/91 have the same dizzy as 90/91
Old Jan 21, 2011 | 06:55 PM
  #2238
91sedan_kid's Avatar
i gotta see some pic of this!
i will definitely take a look! thanks bro! i will also keep you updated on the meet once i get some more info on it. A friend of mines that still goes to the school is hosting the show this year. once i get info i will let you guys know ASAP! the only thing im certain of is that its going to be around the beginning of May most likely a Saturday.
Old Jan 21, 2011 | 07:23 PM
  #2239
I will get some up, here's one at the moment, I'm test fitting the header to weld on the support bracket, and make sure I don't have any clearance problems, I'm also painting this engine compartment one area at a time,
too hard to remove everything at once, so i dismantle one area, paint it, and move on to the next area, eventually it will all be painted, finishing up the mockup under the hood, have to tie up some wiring, and plumbing, and some other small stuff, it's basically put stuff together and take it apart, repeat. I would have been done a long time ago, but there has been a bunch of crap going on the last couple of years. I'm just now getting something done again, i need to get it rolled outside so i can swap in the new dash, it's all ready to go, but I can't open the doors far enough in the garage, once the dash goes in all my new interior stuff goes back in
Old Jan 21, 2011 | 07:30 PM
  #2240
First thing that comes to mind when i see that pic is......tuck...
Old Jan 21, 2011 | 07:32 PM
  #2241
91 crx savage's Avatar
Nice roundtop su's I had rebello su's on my built 240z 2.9 liter
Old Jan 21, 2011 | 07:42 PM
  #2242
these are from a 72 datsun 510 sss, you might recognize the back half of the manifold, or whats left of it. I can't really do a tuck on this one, I've already removed a ton of excess wires and unused junk, some of the wires you see won't be visible, a bunch of them run along the front beam behind the radiator, I've got fuel lines, oil lines, coolant, vacuum etc, and no where to put them, no physical space, it's built to make everything visible anyway. some of the complexity I built to keep the purge canister operational, will be gone, I decided to go to a simple civic one with the solenoid valve built in, and vent the fuel bowls to the air cleaners. I need to keep the canister since the fuel system is sealed. but I can make it simpler, about 30 hours of engineering and fabrication to make it work will be wasted when I take that stuff back out
Old Jan 21, 2011 | 07:50 PM
  #2243
How do those carbs sound
Old Jan 21, 2011 | 07:52 PM
  #2244
91 CRX salvage you might notice there is no head shield between the carbs and the manifold, since it wasn't needed anymore, I got rid of it, I needed a place to put the return springs though, since they would no longer hook on the plate, i ended up making an aluminum plate thats bolted to a piece tig welded on the bottom of the manifold, it has a couple of nappa universal carb return springs on it, worked great until I noticed I wouldn't be able to remove the oil filter, since the filter was now behind it, hence the reason there's a remote oversize filter in the back corner of the engine compartment, usually the way it's gone, move one thing, and move three other things to make something fit
  #2245
jdm ivory eg's Avatar
i wired up my drive light on my eg blackhousings put some amber l.e.d. bulbs picture looks wierd but in person they look completly lite amber.
Old Jan 21, 2011 | 07:54 PM
  #2246
I don't know yet, I want to get this finished so I can hear them!! every time i go to work on it, some bullshit happens and I have to put it on hold, I'm just now getting some serious stuff back together, some of these parts were done a year ago, just waiting to go on
Old Jan 21, 2011 | 07:55 PM
  #2247
da9 all motor: congrats on be coming a member
Old Jan 21, 2011 | 07:57 PM
  #2248
NastyDB8's Avatar
thanks brotha .. we have something really good going here with this thread and members.
Old Jan 21, 2011 | 08:00 PM
  #2249
bnb is going to be known.
Old Jan 21, 2011 | 08:08 PM
  #2250
NastyDB8's Avatar
Fo' Sho' for all the right reasons BNB 4 LIFE!!
