BUILT NOT BOUGHT!
Old Sep 7, 2011 | 11:23 AM
  #6451
DumaDA's Avatar
Default Re: BUILT NOT BOUGHT!
the omni powers are about an inch shorter than his old tein basics so when he slapped them on the front of his car was tucking a good amount of tire, i imagine he's been scraping the **** out of his intercooler piping hhaha
Old Sep 7, 2011 | 12:04 PM
  #6452
Mattb16teg's Avatar
Community Builder
Community Influencer
I need new coils, my Omni's are soo old they are all rusted up. Was a B to raise the car, I tore my knuckles up. Went through 3 cans of WD40 lol!
Old Sep 7, 2011 | 12:26 PM
  #6453
NastyDB8's Avatar
what's up BNB? I have some questions. I have been searching but I figured with the amount of knowledge here in the crew I am sure someone has done what I need to know. Ok I have an opportunity of getting an 88' EF Hatch the body is clean. Now I have my 90' LS B20 Am I able to do a straight forward swap over..meaning taking what I have from my current ride and swap into the hatch. I wanna see if it's worth it and then sell my 90' LS shell. Any help appreciated. (don't hit me)
Old Sep 7, 2011 | 12:31 PM
  #6454
NastyDB8's Avatar
here's the ride
Old Sep 7, 2011 | 12:47 PM
  #6455
91sedan_kid's Avatar
Originally Posted by DumaDA
too low with those omni powers huh hahah, post a pic of the current stance before you raise it
it wasnt too low just had a little bounce to it while driving and i really didnt like it so i raised it just to the point where the coil is touch the tophat. or really close to it.
i cleaned mines a little bit before putting them on so its pretty easy to adjust.
just so your aware.
the motor WILL fit BUT WILL NEED MODIFICATION. your your going to need shift linkage, and mounts. also will need to bang the back so the alternator will fit. its not going to be a straight drop in and go.
Hasport makes mounts and shift linkage for the swap your planning on doing and i say spend the money and get them, its worth it.
you will definitely love the power in the hatch then you will in the integra.
I had a B20Vtec EF hatch and it pulled pretty hard, even with an LS tranny.
Old Sep 7, 2011 | 01:06 PM
  #6456
DumaDA's Avatar
rides better no daniel? looked hella clean at that height though haha
Old Sep 7, 2011 | 01:21 PM
  #6457
NastyDB8's Avatar
Originally Posted by 91sedan_kid
just so your aware.
Can't i just use the linkage I have...I am trying to use as many parts that I already have as possible then when funds are better I can upgrade the motor mounts. I only have about 1,300 bucks to play with and I might have a mechanic buddy help me out so I would have to hit him off , plus the car is $800
Old Sep 7, 2011 | 01:25 PM
  #6458
DumaDA's Avatar
right when you get the EF pull the motor out of your da and sell the chassis then
Old Sep 7, 2011 | 01:31 PM
  #6459
NastyDB8's Avatar
That's my plan I just wanted to get your guys input and If I go through with it , It should take about a day to complete.
Old Sep 7, 2011 | 01:33 PM
  #6460
DumaDA's Avatar
thats what we said about my swap, 1 day turned into 3 weeks, expect the unexpected haha
Old Sep 7, 2011 | 01:35 PM
  #6461
NastyDB8's Avatar
oh Damn what did you guys run into...I ask because i believe if I go through with it I have everything I need. "Looks" like a straight forward swap.no?
Old Sep 7, 2011 | 01:42 PM
  #6462
My_EFsedan's Avatar
you gonna need swap mounts and linkage period. dpfi to mpfi wiring. everything else can be used from the DA.
Old Sep 7, 2011 | 01:43 PM
  #6463
DumaDA's Avatar
for me there was problems with the manifold gasket and the idle was fluctuating along with transmission problems. For you you're taking your swap out of a running car and just moving the whole thing so it should be ok, just get the mounts and shift linkage etc
Old Sep 7, 2011 | 02:10 PM
  #6464
NastyDB8's Avatar
thanks guys for the input. I'll have to wait right now $1,300 is not gonna cover what I want to do unfortunately. I'll just save up some more. thanks again. motor mounts $300 + shift linkage $150 + conversion harness about $175 = $675 roughly + $800 car = $1425.... and I still have to hit the mechanic off for 2 engine removals... oh well looks like I will have to wait.
Old Sep 7, 2011 | 02:23 PM
  #6465
DumaDA's Avatar
or post the shell up right now so that you have a buyer ready to pick it up right when the motor is out
Old Sep 7, 2011 | 02:26 PM
  #6466
My_EFsedan's Avatar
conversion harness?? the dpfi to mpfi?? thats so easy to do yourself with the stock hatch harness. takes me 30mins or so to do it. that saves money there. do your own work of engine removal and save money there. shift linkage can be shorten from the DA and used on the EF but has to be precised otherwise it will have alot of play. save money there. if you are serious i can ask around for some mounts for you from some friends.
Old Sep 7, 2011 | 02:30 PM
  #6467
NastyDB8's Avatar
ok I checked out Innovative and looks like they have the mounts for $174 + shift linkage $ 109 + wiring harness $159 = about $442 plus tax and what not.
Old Sep 7, 2011 | 02:31 PM
  #6468
My_EFsedan's Avatar
whats this wiring harness you speak of?
Old Sep 7, 2011 | 02:35 PM
  #6469
NastyDB8's Avatar
word...dang I wish I lived closer to you guys or you guys closer to me. I don't mind doing stuff myself IF I had the proper tools...but I don't have a lift to get my engine out myself. ha ha takes YOU 30 minutes to convert it might take me a couple hours. lol. Ok so what I would really have to come out of pocket is for the mounts. hhmmmm let me rethink this.
Old Sep 7, 2011 | 02:36 PM
  #6470
NastyDB8's Avatar
I thought I needed a wiring harness to switch the dpfi to mpfi ???
Old Sep 7, 2011 | 02:50 PM
  #6471
OldSkoolDa91's Avatar
you can either re-wire it yourself, or you can send your harness to someone and have them modify it, or you can buy the conversion harness like ry-wire sells. mounts you have to buy. plain n simple. linkage as was said, you can cut down the da linkage and re-weld it but you have to make sure its measured properly and lined up correctly.
  #6472
My_EFsedan's Avatar
you can do it yourself. i do them myself one too many times i know it from the top of my head.
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Old Sep 7, 2011 | 02:57 PM
  #6473
NastyDB8's Avatar
thanks for all the info guys
Old Sep 7, 2011 | 10:35 PM
  #6474
hmm.. Thinking of selling my 97 integra and picking up an 04 TSX next year..
Old Sep 8, 2011 | 07:39 AM
  #6475
NastyDB8's Avatar
Funny you mention that I was browsing at a 2004 RSX type -S
