BUILT NOT BOUGHT!
Here are some pictures of the civic while primering. The primer was laying really good tonight. 71 degrees in the garage at 900pm.
Here is my makeshift paint booth in my 8 car garage
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I just pulled the heat shield out, i need to do a little metal work for the pipe hanger, looks pretty good for being a quarter century old. While it's out i'll clean it up and paint it with some heat paint.
took a picture of some of my nice rebuilt shifter stuff while it was out.
smhthis.
8 car garage! I'm jealous! I'm working on painting mine as well in a two car garage, lol.
How I bought her:
How she looks now:
Lip not fitted in this pic yet - will update
1994 Civic Sedan
Came out standard with a B18B3 motor, A/C, P/S, E/W, E/M, C/L and the boot spoiler.
I bought the car in 2007 with the 15" TSW rims & really cheap drop spring kit.
Since then the following has been done:
Koni Yellow Sport Dampers
Sleeve Overs - 10kg front & 8kg rear
South African spec EK Civic VTEC 15" 'blades'
DIY solid engine mounts (windscreen silicone)
Eagle H-Beam ESP rods
Wiseco Pistons K566M815
ACL race bearings
Competition Clutch Stage 2
Competition Clutch Street Lite Flywheel
B16 Oil Pump
B16 Water Pump
GSR Timing Belt
B16 S4C Tranny
B16A Throttle Body
Chipped OBD1 ECU tuned on Crome
SiR front lip
Work still to be done:
B16A head
ARP head studs
Brian Crower BC0013 Cams
Brian Crower BC0010S Valvetrain
Z-Speed Adjustable Cam Gears
Intake
Throttle Body
*most of the above parts have been purchased & ready to go
All the work done on this car has been done by me and & times with the help of mates. Engineering work was obviously sent out to be done.
How she looks now:
1994 Civic Sedan
ACL race bearings
B16 Oil Pump
B16 Water Pump
GSR Timing Belt
B16 S4C Tranny
B16A Throttle Body
SiR front lip
B16A head
ARP head studs
Intake
Throttle Body
Hey DumaDA what specs are those rims and tires? I think I like that type of fitment for my ride , not that I'm trying to copy yo styzz, but i like the look maybe I might tweak it a bit.
Would 205/50-15 work ok without rubbing,( wait that was stupid question if the 195/50-15 was rubbing then DUH!!! the larger is gonna rub ) also I don't know anything about tire fitment and I hear ppl talking about toe/camber. If you don't mind me asking what setting was it at to have them sit like this " / \ " ?
i never ran a camber kit on that car, just the wheels camber in naturally, i would either lower the car more or roll the fenders more to fit a set up. If your car is slammed and you throw a 195 45-15 on you'll just need a fender roll and you'll be good, those specs are pretty aggressive though, i would prefer the wheels that 91sedan_kid and My_EFsedan are running which are 16x8+20, imo those are the nicest wheels sportmax/xxr has ever come out with
205/50/r16
205 is the width in mm
50 is the aspect ratio or the relation of width to diameter so it is your sidewall
r just means steel belted radial
and 16 is your rim diameter.
generally speaking, people will put 215 tires on 8" wheels but some will go as high as 235 or as low as 195
completly stock ls, lowered on gsr wheels and ugly tan interior. 5 zigen exhaust
built GSR w/ type r lip, Volks LE37 16x7.5 mugen twin loop, usdm ITR seats.
mugen decided to melt my bumper...lol so 5 zigen went back on(01 civic coupe wing)
now:
JDM 96spec ITR swap
01 ITR front
rear
sides
wing
tails
mirrors
5 LUG ITR CONV.
Recaros
full black gsr interior swap!!
Spoon/ mugen and lottssss more!
now:
JDM 96spec ITR swap
01 ITR front
rear
sides
wing
tails
mirrors
5 LUG ITR CONV.
Recaros
More stuff on the heat shield, ready to go back in
reinforcement sheet metal welded in
you'd be the first one and you know honda motor are reliable.
and this is a manly hug
