___||SOHC Squad V.3||___
Old Sep 16, 2010 | 09:05 AM
  #951
RedHatch00's Avatar
Default Re: ___||SOHC Squad V.3||___
hey anyone know why my hatch isn't burning fuel properly at higher rpms
Old Sep 16, 2010 | 10:36 AM
  #952
VTSOHCnon's Avatar
Can you be a little more specific, how do you know its not burning it properly? And what SOHC is it? Millage? Mods? recent maintenance?
Old Sep 16, 2010 | 10:49 AM
  #953
VTSOHCnon's Avatar
Is there anything else you notice about the car about how the car drives or anything at all.
Old Sep 16, 2010 | 11:49 AM
  #954
RedHatch00's Avatar
well the motor is a d16y8 with crx rods and pistons (p72 i believe) stock fuel rail. stock injectors & oem honda headgasket. i noticed blue smoke at about 4000 rpms and higher. recent maintenance was oil change, ngk spark plugs, ngk wires. the motor has roughly 10k miles
Old Sep 16, 2010 | 12:10 PM
  #955
VTSOHCnon's Avatar
Y8's are VTEC heads, I know that VTEC motors consume oil, more so than non VTEC motors. I think the dealers say about a quart every 2,000 miles roughly, if you go around (like me) reving the **** out of your motor. If you drive under 3,500 RPM in every gear, you will notice at a lot less oil will be consumed.
My D16Z6 burns about 1 quart ever 2,500 miles roughly with only 18k on it.
Old Sep 16, 2010 | 01:10 PM
  #956
96EJ6LX's Avatar
Sounds like a valve seal guide leak. I had the same problem. What happens is when you step on it, the valve seal guide is leaking oil into the combustion chamber causing the blue smoke. Heat and rapid movements of the valves causes the seal to expand and let unwanted oil into the combustion chamber. That is what lead to the end of my Y7.
Old Sep 16, 2010 | 01:13 PM
  #957
RedHatch00's Avatar
i got new valve stem seals guess i gotta get those as well. or i just dont beat on the car
Old Sep 16, 2010 | 01:14 PM
  #958
VTSOHCnon's Avatar
How much oil are you using over the time from oil change to oil change?
Old Sep 16, 2010 | 01:19 PM
  #959
96EJ6LX's Avatar
Check your oil every week. If you notice you lose about a quart a week, that will be it.
Old Sep 16, 2010 | 02:38 PM
  #960
SingledOut's Avatar
how is everyone
Old Sep 16, 2010 | 05:04 PM
  #961
Fo-Do Fanatic's Avatar
Originally Posted by SingledOut
how is everyone
Pretty bad Almost got rear ended toda in this rain weather and stomped on it in first missed second and it went into second now second gear grinds above 3500
Old Sep 16, 2010 | 05:16 PM
  #962
RedHatch00's Avatar
thats the thing im not loosing any oil. I change it roughly every 1500-2000 miles. I check it weekly as well too.
Old Sep 16, 2010 | 07:07 PM
  #963
VTSOHCnon's Avatar
Well you must be using some, cause you notice it coming out your tailpipe right when "VTEC kicks in" YO!
From the sounds of things, its nothing you have to worry about yet. Its when it gets worse then a quart in between oil changes.
Old Sep 17, 2010 | 12:04 PM
  #964
RedHatch00's Avatar
yea hopefully i'll find the time to fix it before that. i barely beat on the car. usually shuft around 3500 to 3700 rpms
Old Sep 17, 2010 | 12:21 PM
  #965
RedHatch00's Avatar
oh and btw the car has no cat. converter in it as well so i figured it might have to do something with that as well
Old Sep 17, 2010 | 12:40 PM
  #966
single cam fan's Avatar
what up peeps?
Old Sep 17, 2010 | 01:40 PM
  #967
VTSOHCnon's Avatar
I have a high flow Random Technology Cat and when I shift at 6,500RPMs there is so much blue smoke behind my car, its incredible nothing is wrong with the car. I think the cat has very little to do with it.
Old Sep 17, 2010 | 02:06 PM
  #968
96EJ6LX's Avatar
All a cat does is that it changes the carbon monoxide to carbon dioxide and makes it safer for the rest of the world and tree huggers. for tree huggers. NOT!!!
Old Sep 17, 2010 | 02:07 PM
  #969
RedHatch00's Avatar
^ lol damn tree huggers
Old Sep 17, 2010 | 03:46 PM
  #970
jdm_ek403's Avatar
whats going on..been kinda lost..done some things to the coupe nothing big got spark plugs painted the valve cover got front and back kamber kits .
Old Sep 17, 2010 | 06:29 PM
  #971
96EJ6LX's Avatar
Looking good man. Show some pics of the camber. I <3 camber.
Old Sep 17, 2010 | 11:07 PM
  #972
I should post a picture of my alignmet sheet. I have over -5* of camber in the front I'll post a few pictures of it when it stops raining like 3-5inches every hour here
And I'm picking up some EF9 SiR corner lights and sidemarkers with pigtails next week. WOOT WOOT!!
Old Sep 17, 2010 | 11:20 PM
  #973
Oh and I got this in the mail today
Old Sep 18, 2010 | 03:56 AM
  #974
96EJ6LX's Avatar
Good job man.
Old Sep 18, 2010 | 10:14 AM
  #975
RedHatch00's Avatar
whats up whats up
