___||SOHC Squad||___
Old Jan 27, 2010 | 07:10 AM
  #2626
EJ6-2nr's Avatar
Default Re: ___||SOHC Squad||___
mornin, gonna be in & out today, regional boss is hanging out in the store today ftl
Old Jan 27, 2010 | 12:10 PM
  #2627
fre's Avatar
fre
Originally Posted by GReddy_Civic
Well the handle is molded onto the cable. I dunno. Anyhow, it was only 12$ with my discount at honda. employee discount ftw!
Nice! I need a new handle/cable.
Old Jan 27, 2010 | 01:48 PM
  #2628
GReddy_Civic's Avatar
i need a new set of mudflaps...mine are ground down...like nothing left :D amidoinitrite?
Old Jan 27, 2010 | 02:50 PM
  #2629
jhammond_82's Avatar
Reject Papi
if you had an ef, i have two front mud flaps. i'd sell them cheap. pay for shipping and an extra few bucks.
Old Jan 27, 2010 | 03:34 PM
  #2630
lol if i had an ef, id just come up and get them. I have 2 fronts that are pretty good from the old car...the rears got trashed.
Old Jan 27, 2010 | 03:36 PM
  #2631
lowerex97's Avatar
Originally Posted by 36oh
My engine is running super rich still and I ran out of ideas on fixing it. Also my spark plugs keep getting coated with carbony ****, also very annoying
seafoam in the oil
Old Jan 27, 2010 | 04:54 PM
  #2632
Reject Papi
oh? where you located? lol.
Old Jan 27, 2010 | 05:22 PM
  #2633
lol we discussed this a few pages back. I live in york
Old Jan 27, 2010 | 05:40 PM
  #2634
Reject Papi
ohhh, lol. my bad. sorry. yeah, now i do remember that. haha.
Old Jan 27, 2010 | 11:00 PM
  #2635
C_R_X_V_T_E_C's Avatar
i have a d15b with a y8 head im doing the head gasket/headstuds/timing belt/water pump. its all put back together im just off on the timing.
QUESTION:
ive read things about being off 4.5 degrees on some mini me swaps is that true for mine? is this 4.5 degrees advanced or retared? if mine is included in this how do i set it to be accurate?
also i have a venom adjustable cam gear, where should my -0- mark sit? straight up and down?
i believe the timing is off because i am confused about something.
feel free to ask questions if i didnt provide enough information.
thanks in adavance.
Old Jan 28, 2010 | 02:52 AM
  #2636
CB_ejcoupe's Avatar
Man another slow night on here it sucks not being able to sleep lol, So hows everybody and there cars doin. My hatch still dont run and i need to start working my green hatch so i can sell it.
Old Jan 28, 2010 | 05:46 AM
  #2637
matt j's Avatar
QUESTION:
thanks in adavance.
sometimes you just get to much information, the gear should be set to zero, then put the motor to TDC and i know on my aem gear there is a spot that shows where the cam should be at the tdc location, look for that and make sure you have that at tdc. thats what i did with my old mini me (d15b2 with a z6 head) Let me know if you need anything else
Old Jan 28, 2010 | 06:11 AM
  #2638
Reject Papi
QUESTION:
thanks in adavance.
something with the y8 is different from the rest of the sohc vtec engines. something with the timing. not sure what it is though to be honest with you. have you tried 4.5 degrees either way to get it started? i'm not sure which way to tell you to put it. if it doesn't work one way, try the other. i'm still searching for an explanation, but haven't found anything yet for you.
Old Jan 28, 2010 | 06:16 AM
  #2639
Reject Papi
crxvtec, here is a link i think may be helpful. https://honda-tech.com/forums/hybrid-engine-swaps-18/massive-d16y8-head-onto-d15b7-8-block-minime-swap-writeup-2147115/
Old Jan 28, 2010 | 07:04 AM
  #2640
EJ6-2nr's Avatar
^ that was a good find j, good read too, dude said you had to use an adjustable cam gear, or the stock gear from the 15b on the y7/y8 camshaft IIRC
is there any writeups on putting the vtec head/mani on my 98 dx?
Old Jan 28, 2010 | 07:38 AM
  #2641
EJ6-2nr's Avatar
just found this on the "civic club" wesite lol
appears to be a pretty popular mod, but only half the job i would want:
"D16Y8 intake manifold swap
If you plan to keep the Y7 computer, it's easiest to use a Y8 auto manifold and t/b since the IACV setup is the same. Of course the 5-speed manifold setup works fine too, you just need to block off the IACV opening on the back and swap the throttle rotor & spring over to your Y7 t/b.
If you use the Y8 injectors with the Y7 ecu, you will run rich though so you want to reuse your Y7 rail & injectors. Here's a rundown on how to do it, this is everything I can remember off the top of my head...sorry if it's long-winded!
Here are things to have on hand when you start the project, so you won't have to leave for the auto parts store during the middle of it:
new intake manifold gasket
Y8 manifold brace
about 5ft of 1/4" i.d. hose, suitable for fuel/vapor/coolant use.
about 2ft of 3/8" i.d. hose, same kind of stuff
premixed coolant for aluminum blocks (you're going to lose some!)
*you might want to change PCV valve while manifold is off, it's not easy to get to otherwise.
*if you've got lots of miles and never did fuel filter, nows the time while system is depressurized also.
1) Remove fuse to fuel pump, then start car. When it stalls out, turn it off and remove the negative battery cable. This is to relieve the fuel pressure. Put the fuse back so you don't forget later.
2) Pull out the IAT sensor from the Y7 airbox, remove the box & piping, Also remove the little throttle cable brackets and detach the cable from the t/b and the cable stay.
3) Put some masking tape on the injector branches and mark them 1-2-3-4 so you get them back on the right ones, then pull the plugs. Loosen and remove the fuel hose nut at the fuel rail inlet.Take off the 2 nuts holding the fuel rail on, also I think the harness clips in a couple places on the rail so unhook those clips. Pull the little hose from the regulator to the manifold then lift out the rail/injectors. (If reusing Y7 injectors, install them in the Y8 rail, or just move the Y8 purge solenoid from the Y8 rail to the Y7 rail.)
4) Remove all vacuum lines from the manifold to any other sources. Get some rags and cups handy, now you start unhooking coolant lines! Use some pliers or channel locks to pull the retaining clips down the hoses a bit, then start pulling the hoses off. Splash! Just try not to get the coolant into the injector holes.
5) Using the outside-in pattern, loosen & remove the bolts holding the manifold to the head. There's one bolt on the underside of the manifold that holds the brace onto it, I think it's an 12mm. Grope around for it and remove that too. The manifold should be able to come right out now.
6) remove the old gasket, without gouging the surface underneath. This is tedious and irritating, at least for me it was. It's easy to scratch the head, so if you've got some chemical to soften the gasket up that would be good. Remove wiring clips from the manifold brace, take the brace out too.
7) Get your new PCV valve ready by installing the 3/8" hose & clamp on it. Don't put it in yet...first, remove the small hose from the water pipe right near the PCV (this one is a gusher!) Have a stretch of 1/4" hose ready (15-18") ready to put on immediately. This coolant line will go to the IACV on the Y8 auto t/b, just like it did with your Y7.
8) If the head is cleaned up, put your new mani-gasket on and slide the head into place. Hand snug the bolts up, then start torquing them properly in order. Once it's tight, put the Y8 brace in place and tighten it to the manifold first, then tighten the bolts to the block. If you have a header or downpipe made for Y8, you should get an exhaust support brace for the Y8, it is held on under the manifold brace by the same bolts. It is oriented properly for the support bracket you see by the header collector area on Y8. Y7 is different for some reason.
9) Reconnect the fat coolant line, run a new piece of 1/4" from the IACV to the small nipple that comes off the big one. Cut the new coolant line coming from the pipe under the mani to proper length and connect it to the other IACV nipple.
10) Lightly oil the rubber injector seats, then with the injectors already in the rail, install the rail with injector connectors facing up. Tighten it down, then connect the fuel supply line and tighten it up (don't forget the washer).
11) Use another length of 1/4" hose to run from your purge cannister to the purge solenoid on the rail, then connect the other end of the PCS to the medium sized port under the larger one on the front of the manifold. the upper one is for the PCV 3/8" hose. Now push the PCV down through the hole by the middle manifold nut, go underneath and connect it to the black box. Back up top, route the PCV hose to fit the port & cut to length.
12) I think all the wiring will reconnect without modification except the PCS connector, you might have to lengthen it by 6-8". Reattach the tiny hose from regulator to the little port right near the t/b. Use a small piece of that little hose with a screw in it (or just some silicone) to block off the cruise control vac port on the back driver side of the manifold. Connect the brake booster hose to the big port on back.
13) Plug the wiring back in, make sure you don't mix up the MAP & TPS, they are the same kind of connector. I marked all connectors before removing them just to be sure.
14) Install the cable into the throttle rotor, insert it into the stay, & tighten it up solid with 2 12mm wrenches. Make sure there's no slack but that the rotor isn't open at all when not stepping on the gas.
15) After double checking to make sure everything is hooked up, and you have not crossed and coolant/vac lines, reconnect the battery cable and crank it over. It will take a few seconds to pressurize the fuel system again.
I think that's everything, it should make sense when you are looking it all over and start working on it, this should be a good guide. Hope it helps! "
__________________
Old Jan 28, 2010 | 08:46 AM
  #2642
blubryyum's Avatar
Old Jan 28, 2010 | 08:53 AM
  #2643
Radim's Avatar
Originally Posted by prelude182
give me that hideous wing on the back of your car lol. You should cut the sides off somehow and try to mold it to look like a chargespeed wing. Ive been looking for a wing like that. Do you know the name or brand of it?
It's a cross between a Hiro Spoiler and a Chargespeed spoiler. It has a Made in Japan stamp so might be the real thing but have not been able to find the real maker. It MIGHT just be a hiro spoiler.
CB_Ejcoupe that's cool just let me know when you get around to it.
Old Jan 28, 2010 | 11:22 AM
  #2644
Reject Papi
i spy with my little eye...a flat tire!
Old Jan 28, 2010 | 11:50 AM
  #2645
thanks for the help you guys, but i am really looking for timing and tdc specific write-ups. dis assembly went fine, re assembly was fine. timing is my issue, i believe.
Old Jan 28, 2010 | 11:55 AM
  #2646
blubryyum's Avatar
Haha it'll buff out no problem!
Old Jan 28, 2010 | 12:01 PM
  #2647
Radim's Avatar
Snapped some pics for my buddy/neighbor yesterday, he just got the car about a month ago he's pretty stoked on it, his brother bought an EF after he drove mine about two months ago, he liked how much we were working on our cars so he decided to buy a Honda.
I might get him to join but he's not as tech savvy as most people.
It's a Pearl White 98EX Coupe.
Old Jan 28, 2010 | 04:28 PM
  #2648
single cam fan's Avatar
sup fellas
Old Jan 28, 2010 | 05:06 PM
  #2649
well im pretty srue the y8s have a different amount of teeth on their cam gear compared to the z6, im not sure how that relates to other d's. But just another side note, the y8 oil pumps suck.
Old Jan 28, 2010 | 09:04 PM
  #2650
amaro321's Avatar
Originally Posted by M7EG6
Wat up squad. No man those mounts are not the conversion mounts
Oh okay, It just looked like my transmission mount, i had an automatic and converted it to a manual but I ran into a problem that the tranny mount bracket on the auto differs from the manual so I guess Im going to have to take it off ans Solder on a manual one...any Ideas? any input is appreciated
