Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
BOV and waste gate.....the same??
Old Sep 23, 2004 | 03:14 PM
civiccpedx's Avatar
Default BOV and waste gate.....the same??
I have been doing some research so I can turbo a b18c1 and when I search for a BOV I get BOV and wastegates. are they the same and if not what does the BOV do, I know the wastegate just senses the psi and then lets some exhaust go by if the psi is to high but what about the BOV? Sorry about the nb question but I am new to the boost. Help is always appreciated
Old Sep 23, 2004 | 03:17 PM
sohcvtec1995's Avatar
Default Re: BOV and waste gate.....the same?? (civiccpedx)
no they are not the same. A BOV lets the pressure escape from the charge pipe once the throttle body is closed. A Wastegate opens When the set PSI is reached.
Old Sep 23, 2004 | 03:18 PM
Ricey McRicerton's Avatar
Default Re: BOV and waste gate.....the same?? (sohcvtec1995)
A wastegate controls how much boost you make.
A blow off valve sits upstream of the turbo (between the turbo and the throttle body) and opens based on the throttle body closing releasing the pillar of compressed air in the charge piping into the atmosphere.
Old Sep 23, 2004 | 03:19 PM
dantastic's Avatar
http://www.superstreetonline.c....html
googles ow3ns j00
Old Sep 23, 2004 | 03:20 PM
civiccpedx's Avatar
Default Re: BOV and waste gate.....the same?? (Ricey McRicerton)
So then are the wastegates adjustable quickly, or what would I use to change my psi quick before like a race or something?
Old Sep 23, 2004 | 06:54 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">So then are the wastegates adjustable quickly, or what would I use to change my psi quick before like a race or something?</TD></TR></TABLE>
A boost controler. Also some turbo's stock wastegate can only go down and hight so many psi.
Old Sep 24, 2004 | 08:33 AM
murmur9's Avatar
sorry to jack the thread....but what the **** do i have to do so i can post a new topic in FI form ?
dunkd
Apr 25, 2004 02:35 PM
DownBoyDown
Feb 2, 2004 09:19 AM
igo4bmx
Jun 4, 2003 01:41 PM
GettaluvR
Oct 3, 2002 09:22 PM
TeGsr94
May 23, 2002 07:49 PM
