Zex Wet VS Dry
Old Feb 17, 2004 | 07:53 AM
MooreBoost's Avatar
Default Zex Wet VS Dry
Im looking into a Zex kit and have looked at wet from the start, primarily because everyone I talk to says wet. My local shop however had never heard of Zex, and it is my understanding that such dry kits as NOS provide no extra fuel what so ever. The Zex dry kit does however does add fuel by bumping fuel PSI. So is the Zex wet kit still safer than the dry, or is it about even (assuming a 50 shot is used) ?
Old Feb 17, 2004 | 09:45 AM
vtekthis's Avatar
i had a nos dry kit with a 50 shot and it worked great! the nos kit also bumps up fuel psi when nitrous is applied, just like the zex does, i guess you shop does not know what there talking about. people dont like dry kits because the hightest shot you can run is a 75, reccommended by NOS and zex because of the lack of fuel. in easiers terms if you only want to run a 50 shot and never add more than 75, dry is the way to go, its cheaper and a lot easier to install, but if you want more and more nitrous power, i would suggest the wet kit because there is no limit to what you can spray.
hope that helps!
Old Feb 17, 2004 | 04:28 PM
MooreBoost's Avatar
Default Re: (vtekthis)
The guy at the shop just said, " I prefer wet, keeps you from leaning out."
I was unaware that the NOS kits bumped pressure. Im still on the fence on this one, I dont want to half *** it.
Old Feb 17, 2004 | 04:31 PM
Newt Dog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">i had a nos dry kit with a 50 shot and it worked great! the nos kit also bumps up fuel psi when nitrous is applied, just like the zex does, i guess you shop does not know what there talking about. people dont like dry kits because the hightest shot you can run is a 75, reccommended by NOS and zex because of the lack of fuel. in easiers terms if you only want to run a 50 shot and never add more than 75, dry is the way to go, its cheaper and a lot easier to install, but if you want more and more nitrous power, i would suggest the wet kit because there is no limit to what you can spray.
hope that helps!</TD></TR></TABLE>
The only limit is the motor... Spray to big of a shot (BOOOOOOOMMM!!!!!)
Old Feb 17, 2004 | 04:34 PM
Hoosier Daddy's Avatar
Default Re: Zex Wet VS Dry (tegunderpressure)
I sprayed a Zex dry 50 and 75 shot on my old B16 without any timing retard and it took it like a champ.
Old Feb 17, 2004 | 04:35 PM
Newt Dog's Avatar
Default Re: (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">The guy at the shop just said, " I prefer wet, keeps you from leaning out."
I was unaware that the NOS kits bumped pressure. Im still on the fence on this one, I dont want to half *** it.</TD></TR></TABLE>
I dont think the NOS dry kit boost's pressure.. The wet system work's with two solenoids. One spray's fuel and the other spray's nitrous.. I think you have to manually turn fuel pressure up..
Old Feb 18, 2004 | 08:02 AM
MooreBoost's Avatar
Default Re: (Newt Dog)
Bump, people say the extra 50 bucks is worth the wet kit.
Old Feb 18, 2004 | 08:47 AM
Newt Dog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Bump, people say the extra 50 bucks is worth the wet kit.</TD></TR></TABLE>
Wet is safer... You can control your mixture better..
Old Feb 18, 2004 | 10:18 AM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newt Dog &raquo;</TD></TR><TR><TD CLASS="quote">
Wet is safer... You can control your mixture better..</TD></TR></TABLE>
BojeEM2
Honda Civic (2001 - 2005)
14
Sep 12, 2007 02:13 PM
0618turbocivic
Jul 25, 2006 08:38 AM
eg six
May 29, 2006 05:45 PM
BlackRocket
Oct 9, 2004 07:48 AM
v-tec crx
13
Dec 26, 2001 06:19 AM
