nitrous bottle warmer/heater question
is the NX bottle heater really that much better than say a zex? i mean to the advantages of a NX bottle heater outweigh the face that it costs $100+ more? and a zex bottle heater should work fine on my NX bottle right? thanks
Re: nitrous bottle warmer/heater question (tek_civic)
A heater is a heater?
I'm not saying that one is definatly better than the other but... a heater is not a heater..
heaters are rated by there ability to produce heat.
If one matches the temperature drop of the can better than the other then it's better.
I don't know which is better but I'm sure one is.
D Tranny Guru
Re: nitrous bottle warmer/heater question (Mista Bone)
also note, likely the ZEX heater is just a NX heater, reboxed.
Compare the remote valve openers from both companys.
Re: nitrous bottle warmer/heater question (97hb)
well i know that the NX heater is good, it shuts off at a certian temp and then turns back on when it goes below a certian temp, so if you do leave it on it wont go over into unsafe temps. its a very nice setup
Re: nitrous bottle warmer/heater question (91_EF_Civic)
ok looks like i will just have to get a gague(rather the little blue gague adapter since i have a gague but no adapter) and monitor how it works myself. it should be in on friday.
D Tranny Guru
Re: nitrous bottle warmer/heater question (Dark_Sol)
installer error................
heater would see constant power when igntion was off!!!!!!
Idiot knew this and still tried to sue. He lost.
K24 Turbo EF
10-04-2005 09:55 AM
