z6 build
Old Mar 19, 2008 | 08:45 AM
Rease3's Avatar
Default z6 build
i already have eagle h beam rods. but i dont kno what pistons to go with i dont want low compression i want to keep up/ beat b16 boosted. aiming for 9.0-9.5 compression rate. also what should i do to the head mechine wize? would a stock head but rebuilt with oem parts b fine?
Old Mar 19, 2008 | 10:24 AM
1992Si's Avatar
I don't see any mention of a turbo on your engine. Yet you hope to keep up with a boosted B16?
I don't think that's possible.
check out http://www.d-series.org
Modified by 1992Si at 3:20 PM 3/19/2008
Old Mar 19, 2008 | 02:13 PM
Rease3's Avatar
Default Re: (1992Si)
im on there i have a t25 turbo that im about to put on but im also building a motor and want to nko what are good pistons. my friend he is on here has a b16 and i wanna keep up with him. so i guess no 1 is going to help me [freak] it
Old Mar 19, 2008 | 02:25 PM
mike93eh2's Avatar
youre not going to beat a boosted b-series with a t25 d16 lol
as far as pistons.. get some arias.
Old Mar 19, 2008 | 04:21 PM
Schister66's Avatar
Man U FTW
piston choice really depends on your power goal. If you're looking for a simple 400whp build, snag a set of Vitaras and call it a day. Otherwise, look into Arias, CP, Wiseco, etc...
You're going to need more than just an engine build to have a reasonably fast setup though. What does your turbo setup consist of and do you plan to upgrade that as well??
Old Mar 19, 2008 | 04:28 PM
97grnrs's Avatar
Default Re: (mike93eh2)
acutally block to block u will have a ton more power off the line with a small turbo like that compared to someone with a big turbo.. and u dont even need pistons and rods. stock block is fine . just tune it well.
Old Mar 19, 2008 | 05:21 PM
Rease3's Avatar
Default Re: (97grnrs)
well later on down the road(a year) i am going to get a ls or a b16 and boost that but untill then i want a boosted fast d16. im dont want nuffin outragous that i cant use on the b. i was planning on going t3/t4 63 trim would that b fine for both motors?
Old Mar 19, 2008 | 09:19 PM
redboy183's Avatar
Default Re: (Rease3)
i wonder who that friend you are trying to keep up with is..hmmm
Modified by redboy183 at 8:52 AM 3/20/2008
gmacarize
14
Jul 18, 2007 07:13 PM
b16htchbak
May 30, 2007 09:01 AM
Ak_ef9
Nov 27, 2006 05:57 AM
tRex99
10
Nov 12, 2004 12:16 PM
slipstream
Nov 8, 2004 01:36 PM
