Clutch is not releasing! What to do????
Old May 26, 2003 | 11:05 AM
Hondasaurs's Avatar
Default Clutch is not releasing! What to do????
My clutch is not letting go. I have a cable YS1 tranny. When I shift its really hard to get gears. When I slow down with the clutch in I can feel it grab and cause the engine to shake. I've adjusted the cable and this did not help at all. Any suggestions? I also have a 94 GSR OEM clutch. Will this work withthe YS1 tranny?
Old May 26, 2003 | 11:25 AM
thirdvector's Avatar
Default Re: Clutch is not releasing! What to do???? (B17A Hatch)
I'm not mechanically psychic, but I can tell you what just happened to me. I was having similar problems shifting (without the engine shake). All worked fine except it was exceptionally hard to shift, and at times it would grind or not go into gear at all. I eventually discovered that rev-matching (double clutching) helped out quite a bit. Turns out that my 110k clutch disc had an inner piece of the sprung hub broken completely off. I assume that it was stuck between the disc and flywheel, preventing dis-engagement. Bottom line, your clutch is may be f*cked. Maybe....
Hope this at least gives you a start -Matt
Old May 26, 2003 | 12:14 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Clutch is not releasing! What to do???? (thirdvector)
Check your throwout bearing too. Odds are it's a little, cheap part that's screwing your whole operation.
Old May 26, 2003 | 12:25 PM
Default Re: Clutch is not releasing! What to do???? (Archidictus)
Often, the throw-out (also called release) bearing will make a fair amount of noise when it has gone out. BTW- A spring also popped out of the hub of my girl's 94 LS and it made it pretty hard to shift. It seems that the OEM discs just start to fall apart after awhile. The spring-popping problem is also known to happen on Clutch Master's units under hard launching.
Old May 26, 2003 | 03:27 PM
sauceman's Avatar
Could be something wrong with the pressure plate, maybe the teeth are bent for some reason... too weak??
Old May 26, 2003 | 06:22 PM
Hondasaurs's Avatar
Thanks everyone! I have to change the passanger axle so I guess Ill just do a new clutch while I'm at it.
bradennicely
Apr 23, 2010 07:37 AM
willskillz805
Oct 11, 2009 02:35 PM
92TEGGYGSR
Jul 12, 2004 04:56 AM
o d i e e
Jan 10, 2004 02:06 PM
Hondasaurs
May 28, 2003 08:32 AM
