wrap my intercooler piping?
Old Jul 2, 2010 | 07:22 PM
andrew54's Avatar
Default wrap my intercooler piping?
Is it worth it. I'm not worrying about looks so much. when I use a heat gun it shows almost a 30 degree difference from the outlet of the intercooler to right before the throttle body coupler. I'm not having extreme iat's there around 80-130 degrees. it is aluminum pipping. I have seen header wrap and aluminum reflective wrap used.
will this help me lower my iat's or any one that has had experience with ether
thanks
Old Jul 3, 2010 | 12:25 AM
95skunkedgsr's Avatar
Default Re: wrap my intercooler piping?
some ppl will say it traps heat in some will say it keeps heat soak out . do you have data logging on your ecu ?
Old Jul 3, 2010 | 12:54 PM
andrew54's Avatar
I do have data logging and I can see I real time via aem commuter and my serial guage . Any help or experience or opinion
Thanks
Old Jul 3, 2010 | 04:32 PM
TheShodan's Avatar
Moderator
99.9% of the time it is not needed, unless you are not getting any good air flow into the engine bay from the front. Its really not worth it, nor are there any power gains from doing it.
Old Jul 3, 2010 | 08:20 PM
the only way i can see it helpin is maybe when your on the two step ready to launch and there is no air coming into tho bay because your not moving yet
Old Jul 4, 2010 | 01:02 AM
Tony the Tiger's Avatar
Best method is to prevent the engine bay from getting that hot... Try to wrap the exhaust manifold, build heatshields, ceramic coating, etc.. and trap the heat where it belongs, rather than try to wrap everything else inside the engine bay.
blackeg
Jul 31, 2012 04:37 AM
g_man1968
Jan 23, 2006 02:55 PM
88crxhfb16
Sep 25, 2005 06:59 PM
buck02
Jul 5, 2004 11:43 AM
T3T495GSR
Jun 16, 2003 12:47 PM
