would this clamp hold?
Old Jul 28, 2005 | 05:13 PM
desiromeo812's Avatar
Default would this clamp hold?
[IMG][/IMG]
my coupler off of my turbo keeps on blowing off... gsr with greddy at 7 psi .... would this clamp work because i need it to stay on there until i get T-bolt clamps....jus checkin if any1 has any experciance with these
Old Jul 28, 2005 | 05:19 PM
B6tPoweredMx3's Avatar
Default Re: would this clamp hold? (desiromeo812)
Its an exhaust clamp.
It wont look very pretty but it will probably get the job done.
Old Jul 28, 2005 | 05:23 PM
s2kdre's Avatar
Default Re: would this clamp hold? (B6tPoweredMx3)
just be a real man and run without an airfilter for a week. lol
Old Jul 28, 2005 | 05:36 PM
Default Re: would this clamp hold? (jdmhonda)
i dnt got no filter jus a screen this is for the pipe that goes to my FMIC.... dnt care about it lookin pretty .. jus worried about it leakin maybe
Old Jul 28, 2005 | 05:51 PM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by desiromeo812 &raquo;</TD></TR><TR><TD CLASS="quote">i dnt got no filter jus a screen this is for the pipe that goes to my FMIC.... dnt care about it lookin pretty .. jus worried about it leakin maybe
I wouldn't be worried about it leaking, but rather the clamp actually cutting into your coupler.
Just go to your local hardware store (Home-Depot...ect) and get a worm clamp for a buck or 2.
Old Jul 28, 2005 | 06:02 PM
Timmay's Avatar
Default Re: would this clamp hold? (Bryson)
T-clamps are your friend
Old Jul 28, 2005 | 06:07 PM
AspectIndustries's Avatar
Default Re: would this clamp hold? (Timmay)
Why not double clamp with the old clamps now, until you receive the t bolt?
Old Jul 28, 2005 | 06:09 PM
Default Re: would this clamp hold? (synik)
tried all that they jus ****** keep breakin from over tightnin... other wise pipe blows off.. i will get tbolt ones but this is for like a week or so... so jus askin if it would hold
Old Jul 28, 2005 | 06:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by desiromeo812 &raquo;</TD></TR><TR><TD CLASS="quote">tried all that they jus ****** keep breakin from over tightnin... other wise pipe blows off.. i will get tbolt ones but this is for like a week or so... so jus askin if it would hold</TD></TR></TABLE>
bead roll your pipes...
Old Jul 28, 2005 | 06:18 PM
H22 CD5's Avatar
the Tridon worm-type hose clamps work pretty well for me. make sure that the strap is stainless steel instead of that other material that strips with any moderate amount of force.
also, spray some hairspray on the inside of the coupler before you slip it over the compressor outlet before you tighten the clamp. im boosting 10psi and im still using worm-style clamps.
Old Jul 28, 2005 | 07:10 PM
evilone's Avatar
Default Re: (H22 CD5)
i would put some type of bead on the pipe,, if you have that go to NAPA and ask for constant torque clamps they work well and they are fairly cheap
Old Jul 28, 2005 | 09:37 PM
darkdayz's Avatar
Default Re: (prostock)
The edges of that clamp look a lil sharp and might end up cutting your coupler
Old Jul 28, 2005 | 10:54 PM
ramennoodles's Avatar
Default Re: (darkdayz)
also make sure the pipe and coupler is clean. I had a pipe that keep slipping off because it had some oil or grease or something on it
Old Jul 28, 2005 | 11:12 PM
quick_DC5's Avatar
If youre only boosting 7 psi and your pipes are blowing off something is wrong. I guess youre already getting T bolt clamps and this a just a temporary fix, but how about this.... just stay out of boost.
Old Jul 28, 2005 | 11:15 PM
SHystrdyGSRtdy's Avatar
Default Re: would this clamp hold? (yoboslayer)
use some hair spray on the couplers/pipes
HT Chaplain
Welding / Fabrication
Nov 12, 2007 11:00 PM
RACEPAK
14
Dec 30, 2005 10:06 AM
coupon
Aug 13, 2005 12:16 PM
RACEPAK
Feb 19, 2005 09:30 PM
-iLLuZioN-B18C1
Oct 18, 2003 01:45 PM
