would a built LS motor with stock bore beable to spool a this T70
Guest
Posts: n/a
Would a BUILT LS motor with STOCK BORE 1.8L beable to spool a this T70???????
SUPER 13B TURBO
MONSTER STONE " T70 "
FOR A GREAT POWER BOOST
WET FLOATING BEARINGS
WET FLOATING BALL BEARINGS
SHAFT & WHEEL TRIM 64.5mm
COMPRESSOR WHEEL SUPER 70 60.5mm
TURBINE HOUSING A/R .84
COMPRESSOR HOUSING A/R RATIO .70
SUPER 13B TURBO
Re: would a built LS motor with stock bore beable to spool a this T70 (RiceRocket12s)
.84 A/R on a T4 turbine... you're going to have to be REALLY built, be revving REALLY high, and have a lot of headwork to get it flowing well.
What are your goals and where will the car be driven?
it will spool
i have the same turbo, well a t61 same AR as u also jus they gave yours the name of t70
notice the turbo has a twin scroll design?
the purpose of the turbo is so u can get better spool time
o and mine is going on a d16
Guest
Posts: n/a
Re: would a built LS motor with stock bore beable to spool a this T70 (jdmchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop »</TD></TR><TR><TD CLASS="quote">it will spool
o and mine is going on a d16 </TD></TR></TABLE>
yea thats what i thought the twin scroll was for .... when do you think it would spool by ?
Im going for low 12s high 11s .... its going to be a fully built head and the blocks going to be pistons,rods,head studs, headgasket, and block guard and tunning is going to be AEM EMS
thats ssautochrome turbo right? its not name brand... i would just go with a precision sc61 or garrett t3/60-1 if u want a big turbo.
Modified by dunkd at 7:17 PM 3/21/2004
