I never want to overboost again!
Old Sep 6, 2003 | 09:07 AM
Hoosier Daddy's Avatar
Default I never want to overboost again!
It's happened way too many times. Would you go with a manual or electronic boost controller to better prevent this? From what I understand, electronic is better. Also, any other tips/suggestions to prevent overboosting would be greatly appreciated. I can't blow another motor
Old Sep 6, 2003 | 09:08 AM
DaveF's Avatar
Default Re: I never want to overboost again! (Xenophobe)
get a good wastegate. and watch the boost gauge..its not that hard to see.
Old Sep 6, 2003 | 09:10 AM
Default Re: I never want to overboost again! (2.2Lcivic)
Kinda got curious last time and kept going I want 6psi from my T28. I have a HKS manifold. Which wastegate would you recommend? I have an internal gate right now...
Old Sep 6, 2003 | 09:14 AM
DaveF's Avatar
at least a tial 35mm.
Old Sep 6, 2003 | 09:18 AM
Thank you sir Gonna look into that.
Still looking for a boost controller as well, not sure what to get...
Old Sep 6, 2003 | 09:19 AM
Overblown-Teg's Avatar
your internal wastegate should work fine if its setup right,.
Old Sep 6, 2003 | 09:46 AM
Mighty Mintos's Avatar
get a fat 60mm hks wastegate. boost hold steady, no boost creep at all!!
Old Sep 6, 2003 | 09:49 AM
Default Re: I never want to overboost again! (F20bcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20bcivic &raquo;</TD></TR><TR><TD CLASS="quote">get a fat 60mm hks wastegate. boost hold steady, no boost creep at all!!</TD></TR></TABLE>
Isn't that overkill?
Old Sep 6, 2003 | 06:44 PM
PHiZ's Avatar
Why is it, that you are boost creeping? Also, electronic boost controllers have electrical solenoids, and they require maintenance, and care. A manual boost controller is a simple mechanical device, and if you get a quality one, you should have problems...
I found this site the other day, and It was easy enought to remember: http://www.boostcontrollers.com
-PHiZ
turbo_d
Jun 5, 2022 06:46 PM
ek9vboi2
Jul 18, 2004 08:14 PM
Broken Gearbox
Jun 8, 2003 02:12 PM
austrian type-R
Feb 12, 2002 07:45 AM
