wiring a slim fan
Old Apr 4, 2005 | 06:30 PM
turboteg96's Avatar
Default wiring a slim fan
Hey, i know this is not the right section but i am kinda in a bind here. I just hooked up my new manifold and I had to buy a new fan. Well now the fan will not turn on from the cars signal. If I give the fan 12v from the batery it comes on right away. Please help I NEED my car for tommorow.
Thanks,
Old Apr 4, 2005 | 06:42 PM
J337_UNIT's Avatar
Default Re: wiring a slim fan (turboteg96)
i wired my slim fan to a switch.. i just let it run 24/7... maybe you can try somethin like that?
Old Apr 4, 2005 | 06:43 PM
PrettyLude's Avatar
it should be able to work with the oem harness and fire right up with it
Old Apr 4, 2005 | 07:17 PM
Alchemist's Avatar
Default Re: (PrettyLude)
Cut stock harness, and Blue wire goes to blue wire and black goes to black. If you need a fan I have some for sale. Check sig.
Old Apr 4, 2005 | 09:38 PM
T4eg's Avatar
Default Re: (Alchemist)
fan motors are reverse polarity...means power and ground 1 way the fan will "pull" switch them other way it will "push". It should work no matter how u have it hooked up.
Chris
Old Apr 4, 2005 | 10:46 PM
integlspwr2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alchemist &raquo;</TD></TR><TR><TD CLASS="quote"> Cut stock harness, and Blue wire goes to blue wire and black goes to black. If you need a fan I have some for sale. Check sig. </TD></TR></TABLE>
damn best instructions i have read to date..
Old Apr 5, 2005 | 04:22 AM
turboteg96's Avatar
Default Re: (integlspwr2k)
Update, I hooked up the stock fan just to test and it would'nt turn on either. So, I must of blew the relay or something. the fan is setup backwards with the Ground going to the positive to make it act as a pusher.
Last night in a mad panic, I made my own relay with a switch in the car. This will do for now, next, I am going to try a relay.
Thanks for the help
Old Apr 5, 2005 | 06:46 AM
PrettyLude's Avatar
check the relays and fuses next
vti444
Aug 4, 2007 11:07 AM
nebulight
Nov 6, 2006 11:43 AM
Lucky_Smurf
Aug 2, 2005 02:19 PM
budget
Jul 22, 2005 12:16 AM
goldito187
Oct 30, 2003 11:18 AM
