wiring injectors
Old Apr 6, 2009 | 06:06 PM
hastingsr's Avatar
Default wiring injectors
I got some mitsu 360cc injectors, code is bdl360, I am goin to use for my turbo set up, I have no clips for them so what clips should I get, and what resistor box should I also use.
Old Apr 7, 2009 | 03:17 AM
hastingsr's Avatar
Default Re: wiring injectors
I believe they have the same clips as the mitsu 450's, are there any honda clips that will work or do I need to track down some dsm clips
Old Apr 7, 2009 | 08:35 AM
boostedcivicsir's Avatar
Mr. Badwrench
obd0 clips should work, and there are many threads pertaining to resistor box installs.
they arent gonna net you much power though. whats your goal?
Old Apr 7, 2009 | 10:00 AM
b20beast83's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/complete-diy-plug-play-obd2-civic-resistor-box-write-up-ej6-ej7-ej8-em1-eg1-eg2-eh6-2073540/
Old Apr 7, 2009 | 10:46 AM
hastingsr's Avatar
just looking for a little over 200hp, should be good for what im looking for, i got them for 30 bucks so I cant complain, and thanks for the write up
Old Apr 7, 2009 | 11:23 AM
hastingsr's Avatar
I went out to look at my car for the dead end connector for the resistor box and theres nothing there?? I know the engine was swapped in, could they have cut off the connector or could it be in another place? Seems I may have to wire in my own resistors.
AZNracerx1989
May 15, 2006 07:24 PM
80884
Oct 23, 2005 01:12 PM
boostedblack99
Aug 28, 2005 07:47 PM
Happyman
Jul 7, 2003 06:37 AM
importfan2
Mar 14, 2003 12:00 PM
