DSM injectors
Old May 15, 2006 | 06:07 PM
AZNracerx1989's Avatar
Default DSM injectors
Will DSM 450cc blue tops work on a 2001 integra ls T3 at 9-10 psi?
What is required to install the dsm injectors? How does it connect to the resistor box? Thank you.
Old May 15, 2006 | 07:24 PM
97turboteg's Avatar
Default Re: DSM injectors (AZNracerx1989)
yeah, its possible, i put them on my 97 integ ls. You will have to buy clips off a obd1 honda to connect to the injectors, along with a resistor box or go the way i went with some $5 10ohm inline resistors from radio shack. Its an easy process. But if you go with the inline resistors, then you will have to cut into your wiring harness, and if you dont want to hack into them, then go with a resistor box. if you need to know how to wire a resistor box i got a diagram ill show you...if you got any other ?'s let me know. good luck
MTVtec
May 13, 2009 09:26 AM
food
Dec 29, 2007 06:49 PM
RSX8600
Aug 17, 2004 04:53 PM
sivik2nr
Jun 11, 2003 09:59 PM
