which windage tray and oil pan/oil pickup with GSR girdle
I have a B18B GEM sleeved B18B with a GSR main cap girdle. I am pretty sure that I need a GSR windage tray (correct?) but dont know if I can use an LS oil pan/oil pickup with the GSR windage tray.
Re: which windage tray and oil pan/oil pickup with GSR girdle (88CRXHybrid)
you need both the pickup & pan, as well as the 6 middle main cap bolts from a b18c to go along with the girdle.
Re: which windage tray and oil pan/oil pickup with GSR girdle (qwkteg125)
The girdle was already attached to the bloack when I got it. So I do need the GSR girdle , oil pan, and pickup.
If the girdle is already on the block you are lucky because you don't have to get the main caps machined. Since you have the girdle (and I assume the GSR bolts to hold it in), you'll just need the pickup and the windage tray. Your oil pan should work fine.
Ben
Ben
Re: which windage tray and oil pan/oil pickup with GSR girdle (Bnjmn)
i hope the mains are original on the center 3 mains with just a girdle on top of them... if not... u cant use them without machining them
an ls oilpan won't work unless you take a BFH & smack the crap out of the shallow end enough to clear the windage tray.
