Apexi turbo timer
I bought a apexi turbo timer, and i need to install it. But the instructions are in Japanese and i can only read English. So if anyone knows where i could find the wiring diagram i would appreciate it. Or if they could tell me what color of wire goes where it would be really helpful thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo »</TD></TR><TR><TD CLASS="quote">i bought a harness from lightning i think and its plug and play
works great</TD></TR></TABLE>
I thought about getting this for my Apexi, even though it's already hooked up, but what about the A/F meter?
works great</TD></TR></TABLE>I thought about getting this for my Apexi, even though it's already hooked up, but what about the A/F meter?
I don't deny that you searched the site and found the tech section... Can be kinda confusing. Basicly, look it over a couple times, find out which wire is which and then test out the leads on the back of your ignition switch and basicly match them up. Mine was hell to install because nothing was working right, then I found I had bad ign. switch. If you have an troubles...post 'em
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A Grenade »</TD></TR><TR><TD CLASS="quote">I thought about getting this for my Apexi, even though it's already hooked up, but what about the A/F meter?</TD></TR></TABLE>
i dunno.. i never hooked that up.. but battery option works
i think u have to hook up a wire to the o2 sensor i need help on this also
id unno which wire to hook up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo »</TD></TR><TR><TD CLASS="quote">i dunno.. i never hooked that up.. but battery option works
id unno which wire to hook up.</TD></TR></TABLE>
here's the link it tells you exactly which pin to connect it to
http://apexi-usa.com/productdo...r.pdf
id unno which wire to hook up.</TD></TR></TABLE>here's the link it tells you exactly which pin to connect it to
it tells you in the link i gave above, but it will only serve like an autometer a/f gauge, rich or lean
id unno which wire to hook up.</TD></TR></TABLE>it tells you in the link i gave above, but it will only serve like an autometer a/f gauge, rich or lean
