will running lean cause wierd overheating?
Old Apr 9, 2005 | 12:52 PM
batboyvaj's Avatar
Default will running lean cause wierd overheating?
i just got my b18b with 750's aem ems, 57trim up and running. crusing is fine. when i start boosting the temps start rising. so i did a data log and its running really lean. did a 2nd gear boost and the wideband was reading 15 so i shut it down and waiting for tune. i'm wondering because i'm going to go tune this fri and want it to be working right. i've been reading and it could be head lifting, hg. but i'm thinking its not the hg cause it only heats up when i boost and its running REALLY lean. so that may be the cause. trying to get a dual core rad in before the tune.
Thanks for any input
Old Apr 9, 2005 | 12:55 PM
s2kdre's Avatar
Default Re: will running lean cause wierd overheating? (batboyvaj)
runnin rich heats thing up more. Dont boost on a base map its not worth it.
Old Apr 9, 2005 | 11:42 PM
turtle-eg's Avatar
Default Re: will running lean cause wierd overheating? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">runnin rich heats thing up more. Dont boost on a base map its not worth it.</TD></TR></TABLE>
Actually I believe it's the opposite... running lean makes the engine get hotter, also retarded timing heats up the motor..... Running rich, the fuel cools down the mixture and combustion.
Old Apr 10, 2005 | 05:31 AM
crispydee's Avatar
Default Re: will running lean cause wierd overheating? (turtle-eg)
I agree with the above. I had the head lifting on my B16, it was fine off boost but as soon as you hit boost the temp went straight up to the red.
Old Apr 10, 2005 | 06:44 AM
Johnny_Rocket's Avatar
Default Re: will running lean cause wierd overheating? (crispydee)
Lean-Hot
Rich-Normal
Old Apr 10, 2005 | 06:52 AM
Finland's Avatar
depending on timing, you may be burning fuel in the exhaust manifold, that would give you false "high" EGTs. Since your AF is lean, this is probably not the case.
Old Apr 10, 2005 | 10:24 AM
batboyvaj's Avatar
so you guys think its a hg? just want to make sure because this fri the car is going to get tuned and i don't want to have to stop the dyno tune after 2 runs. should i do arp's and a hg....or do you guys think that i'll be ok?
Old Apr 10, 2005 | 10:40 AM
blundar's Avatar
compression test? more than 5% variation from cylinder-cylinder gives me cause for concern.
Old Apr 10, 2005 | 05:45 PM
batboyvaj's Avatar
i'll do one later on tonight
Old Apr 10, 2005 | 07:39 PM
Default Re: (batboyvaj)
Off topic... But do you have pics of the downpipe you're selling?
Judge Owens
Feb 28, 2015 06:00 PM
97grnrs
Jan 2, 2008 04:00 PM
Schister66
May 21, 2006 02:52 PM
TurboTeg23
Apr 29, 2004 12:34 PM
spike
Aug 12, 2003 03:37 PM
