will machining a crank make it an less reliable?
Old Aug 20, 2006 | 08:06 AM
97grnrs's Avatar
Default will machining a crank make it an less reliable?
i have a spare ls block sitting around but the crankshaft has some knicks it in.. it will prob need to be at least ten under or whatever when it gets machined but will that make it less reliable when i use it someday? it will see some abuse when its used so just wondering.
Old Aug 20, 2006 | 08:16 AM
turbotime's Avatar
are you reffering to micropolishin the bearing surfaces? No that wont decrease reliability it will increase it just make sure you get the correct size bearings for the machined crank sa they wont be the same as the stock
Old Aug 20, 2006 | 08:46 AM
NJIN BUILDR's Avatar
Default Re: will machining a crank make it an less reliable? (97grnrs)
I would not use or recommend a reground Honda crank.Honda cranks are Nitrated when new.It's a surface hardening treatment that has a lot to do with the reliability of honda cranks.This treatment does not perpetrate very deep.Most of it will be ground away in a .010" regrind.It can be retreated but will then need to be lightly ground again.This will all cost alot more than finding a good used crank.You will also be limited in bearing sizing with undersizes.
Old Aug 20, 2006 | 09:15 AM
97grnrs's Avatar
Default Re: will machining a crank make it an less reliable? (NJIN BUILDR)
ok well where is a good place to find a crank .. auto stores prob only sell regrinds
Old Aug 20, 2006 | 10:05 AM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">I would not use or recommend a reground Honda crank.Honda cranks are Nitrated when new.It's a surface hardening treatment that has a lot to do with the reliability of honda cranks.This treatment does not perpetrate very deep.Most of it will be ground away in a .010" regrind.It can be retreated but will then need to be lightly ground again.This will all cost alot more than finding a good used crank.You will also be limited in bearing sizing with undersizes.</TD></TR></TABLE>
agreed. For the price of re-nitriding a crank you might as well just buy one that doesnt' need machining.
poppypizza
Jan 8, 2008 08:42 PM
DanishR
Oct 7, 2007 07:41 PM
hondaeg8
Mar 22, 2005 12:50 AM
SpeedDreamz.com
May 19, 2004 08:34 PM
scratchback
Sep 26, 2001 06:35 PM
