Will this drain work?
Old Jun 9, 2010 | 09:47 AM
30psi_gst's Avatar
Default Will this drain work?
This is the best i could do with this manifold. That is with the turbo actually clocked somewhat to allow the drain to actually sit higher. Manifold is made for the motor. And my drain plug on my motor isnt that high (or at least to me it isnt).
Old Jun 9, 2010 | 09:55 AM
96 GSR-T's Avatar
Default Re: Will this drain work?
I ran my old Precision T67 like that and I didnt have an issue, but it eventually bothered me enought to fix it, what fitting are you using on the turbo?
Do I see a low spot or is it the angle of the camera?
Old Jun 9, 2010 | 10:05 AM
tegman23's Avatar
the drain looks ok...I would get ss line for the oil coming into the turbo..IMO
Old Jun 9, 2010 | 10:41 AM
hondapowerb16a2's Avatar
I would ditch the heater hose and get some hose that is rated for oil the heater hose is going to get soft and deteriorate and will start leaking after a while
Old Jun 9, 2010 | 08:34 PM
Hybrid96EK's Avatar
Geez... Use enough Hondabond on that oil pan?
Old Jun 9, 2010 | 10:19 PM
30psi_gst's Avatar
upgrading the hose is no problem. I have steel braided laying around here somewhere. It doesnt have any dips in it, its just parallel for a long period of time. Turbo oil drains call for no less then a 35* angle. This is just a straight 90 off the turbo and then its pretty much flat until it gets to the pan. You have no idea how much this worries me but the manifold i have sits the turbo so damn low. Just another reason for me to buy a top mount.
I dont like hondabond but a friend of mine swore by it and i got tired of hearing him say it. I always run a gasket with a VERY thin layer of RTV on both sides of the gasket. Thats how we did it on the race cars where i used to work so i just carry it over to my pieces of ****. Theres really not alot of it there. It just all pushed out when the pan was tightened and i didnt feel like taking a blade to it.
Old Jun 10, 2010 | 04:39 AM
kyden's Avatar
do you have a drain flange with an adapter on it? i can't tell from the pic.
a 90 degree fitting off the turbo is a bad idea though.
Old Jun 11, 2010 | 10:55 AM
Tulo's Avatar
That's a boost reference line mang.
What if you clocked the center section the opposite way? I.E., looking at it from this photo, rotate the center section counter-clockwise about 60 degrees. Plug the current tap on the pan, and re-tap it on the other side of the compressor discharge. That would give the oil return the straightest route possible to the pan and require only a small length of return line hose. This would help to eliminate any oil backup that the current horizontal return setup might cause. I hope I described that well enough for you to be able to visualize. Anyways, the rule of thumb is to have the shortest return line possible, and what I described would definitely achieve that.
Let me know if that doesn't make sense. I might be able to make a diagram or something that would help describe what I'm thinking.
Old Jun 11, 2010 | 12:26 PM
JKov240's Avatar
What he said.
Old Jun 11, 2010 | 07:05 PM
heavy duty's Avatar
Originally Posted by JKov240
What he said.
+2
Old Jun 12, 2010 | 01:53 PM
Tulo's Avatar
FeedBack159
Honda CR-V & Element
17
Mar 17, 2014 09:35 PM
Integra21
Nov 30, 2005 09:56 AM
stizzit
Sep 16, 2004 09:17 AM
BEEYOND
Sep 2, 2004 01:08 PM
airwalk07143
Jan 25, 2004 03:00 PM
