JG HEAD!
Old Jun 5, 2010 | 10:43 AM
88 EF Hatch's Avatar
Default JG HEAD!
Alright so im posting this becuz ive heard nothing good about this shop, and unfortunately I didnt do the research before I bought the head. I bought a gsr JG head port and polished, and with JG's complete valve train. I bought it with 0 miles and for a relatively good price. I haven't gotten the head checked at a machine shop, but i want to hear some feedback from you guys. Is this head worth even getting it checked? how good/bad is their valve train? I have read many threads about Javier's shop being shady cuz he never ships blocks/heads, I have the head on me so thats not the problem, I dont really want to know about how he has screwed ppl over like that, I want to hear from those that actually have used his heads or have seen his heads in use. Will his head hold up a good 500hp easily without worrying about it giving out? I need to make sure before I slap the head on my block. please give me some feed back
Old Jun 5, 2010 | 11:05 AM
Turbo-LS's Avatar
Default Re: JG HEAD!
well if you were only shooting fo 500whp then you should have just left it a stock head or some dual valve springs and thats it. you dont need to touch a vtec head untill you trying to extract every bit of power out of the setup ie sfwd or outlaw car
Old Jun 5, 2010 | 09:06 PM
Well I didn't explain myself, I'm going to run a setup to push 500 whp, to get used to the power and learn how to drive a turbo car, and then I'm gonna go bigger, so my block and head are fully built (sleeved, pistons, etc...) but the I need feed back on how jg heads have worked for others
Old Jun 6, 2010 | 03:51 AM
non-VTEC's Avatar
the JG head will work perfectly fine....even if it's not ported as good as some others it will still make the power you are looking for. like turbo-ls said even a stock head can make those numbers. im sure that head will be perfectly fine.
Old Jun 6, 2010 | 05:47 AM
ME=ADRIAN's Avatar
ive had jg's valvetrain on my car for about 2 years no prob... there was fake stuff floating around ebay which was failing due to aluminum retainers etc but if u got a pro-series head odds are its good to go..might wana get it checked out @ a machine shop for extra insurance tho..doesnt hurt.
Old Jun 6, 2010 | 04:02 PM
Yea this is a real jg head, it has the serial number and his stamp, now me=adrian did u have ur head checked after u received it from jg? Was it assembled by them? And how much power are u running on ur setup with no problem? If I decide to go bigger with power cuz I do plan on doing so after a couple month of breaking my self into a boosted car, what can this jg head hold up? I plan on goind like 700whp later, will jg's pro head hold up?
Old Jun 7, 2010 | 05:48 AM
BADGUYNY's Avatar
A friend of mine bought a JG head not too long ago and its been nothing but problems. First off apparently JG shaves all their heads down to the limit, and this head was shaved uneven. Then a valve job wasnt done with the port and polish job and I believe one or two of the chambers were oval shaped. He tried to contact JG a number of times but no response. Head is now at another respectable head shop getting everything fixed....
Old Jun 7, 2010 | 06:20 AM
lsvtecracer's Avatar
I've ran a jg head for over 5 years with no problem. It's the fully built one with the single valve springs. I ran ipg v1 cams with the jg valvesprings and rev up to 10.5k rpm. I wouldn't worry about it too much.
Old Jun 7, 2010 | 07:42 AM
94superteg's Avatar
I have a jg head on my lsvtec setup. With a smaller turbo on the last setup the previous owner made 550 whp no problem. I have the motor and am going with a bigger turbo then he had.
Old Jun 7, 2010 | 02:28 PM
HKSevo9's Avatar
wow... i've been out of the scene for a decade or so... but damn, I didn't know JG fell off like that! These guys used to have pretty decent work back in the day.
Old Jun 12, 2010 | 09:21 AM
alright so everyone has different reviews, I guess ill have it checked to see if it was milled at a str8 angle, other wise it wont seal when i slap on block, so i will have that checked asap
Old Jun 12, 2010 | 10:25 AM
littlewagon's Avatar
Several years ago JG was thee name in Honda/Acura performance. If your car was fast and breaking records, then you were most likely running a JG head, cams or some other product. Unfortunately some poor business decisions lead to a downward spiral that eventually compromised the quality of work and craftsmanship coming out of that shop. Shady business practices and cutting corners to save a few bucks didn't help either.
For peace of mind alone I would have it inspected by a reputable machine shop.
Could save you headaches in the future. Good luck.
Old Jun 12, 2010 | 02:37 PM
Alright I will have it checked. Thanks you guys, but just to make sure after having the head checked, the only rhing I should not worried about is if the valves are sealing correct? Cuz it has a fresh port job and head has to be heat cycled for it to seal correctly? Cuz if I have them lapse valves it will hurt airflow after head been broken in. Right?
josh green
Oct 24, 2010 07:52 PM
88 EF Hatch
Jun 7, 2010 12:18 AM
chris2000
17
Dec 7, 2006 12:50 PM
AutoTrenz702
Jan 21, 2006 10:12 PM
