Will changing the dizzy affect tune?
Old Jun 7, 2014 | 08:24 PM
  #26
civic-steve-94's Avatar
Default Re: Will changing the dizzy affect tune?
That would have made this much easier if that was said previously.
Old Jun 8, 2014 | 07:02 AM
  #27
wantboost's Avatar
Who is Mr Robot?
I hope you at least made a note of what base timing was set at, if not the entire tune will be off.
Old Jun 8, 2014 | 09:23 AM
  #28
Flr Power's Avatar
Originally Posted by turbohatch96y7
If the timing is retarded too much peak compression happens before the spark event and fuel is left unburned.
Not really. You would have to use negative timing to have significant unburned fuel left.
Old Jun 8, 2014 | 05:22 PM
  #29
SPOOLINmatt's Avatar
use digital timing light, set to 16* and make the TDC mark line up.
Old Jun 8, 2014 | 06:54 PM
  #30
wantboost's Avatar
Who is Mr Robot?
But we are assuming the distributor was set at 16* for the initial tune... really it could have been anywhere within it's adjustment range.
Old Jun 12, 2014 | 07:35 PM
  #31
When Joe@Locash tuned my car he busted out the timing light to double check before he tuned it. That should always be done.
Old Jun 16, 2014 | 10:20 PM
  #32
a1320honda's Avatar
With a car up to temp and idling at 750-950, on Crome i got into the idling portion of the map, and set it to 16.5*. And then use the timing light set to 0 and set the timing according to the middle mark on the crank pulley. Some are red, some are white depending on the car. On more advanced managements like Hondata, Neptune etc. you can go in and lock timing at a set number. I set timing on ever car i tune.
Old Jun 16, 2014 | 11:56 PM
  #33
wantboost's Avatar
Who is Mr Robot?
Yea ignition sync really is the best way to do it
without knowing what the dizzy was originally set at the only way I can see to do it right is to set the dizzy at 16 and tweak the tune from there. anything else is just guess work.
brokenojoke
Engine Management and Tuning
Jun 14, 2008 09:50 PM
sikek1
Apr 28, 2008 05:49 AM
civic j
Aug 17, 2007 08:10 AM
bazookatooth
Apr 23, 2005 11:56 PM
tampaSi
Aug 16, 2001 04:16 PM
