pistons
Old Nov 5, 2007 | 07:12 PM
recon23's Avatar
Default pistons
I have an ls vtec b18 with b16 head. I have the ls pistons (lower compression). I want a little but more pull so i was wondering if i could swap gsr pistons in, and notice any differnce. Another question is I plan to boost within the next year or so, and are gsr pistons safe for boost at a higher compression, or should I just stay with the ls pistons?
Old Nov 5, 2007 | 07:20 PM
SleeperGSR's Avatar
Default Re: pistons (recon23)
the reason you get more pull from swaping pistons is that you are increasing the compression ratio. If you boost you will want to lower the compression ratio. If you run a high compression piston and boost you run into reliablity issues as it's not good for the motor, unless it is tuned all the time and run on race fuel.
check this out http://www.c-speedracing.com/h...c.php
Old Nov 5, 2007 | 11:17 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: pistons (SleeperGSR)
Stick with the LS pistons Sir ...
Old Nov 6, 2007 | 04:29 AM
Bignel00's Avatar
ls pistons are fine for boosting . just get some arp rod bolts., all you need is a good tune!
Modified by Bignel00 at 7:15 AM 11/6/2007
Old Nov 6, 2007 | 04:50 AM
evildc2's Avatar
Use ls pistons if you gonna boost it , arp rod bolts is a good advice like our friend just mention,try to consider some H-BEAM rods for that set up and arp head studs also, good luck
djking
Aug 14, 2010 07:44 PM
almostjdmeg
Oct 8, 2008 08:33 AM
jksmith
Mar 24, 2008 02:06 PM
tealsvteceg
Feb 14, 2008 06:03 PM
turbohf
Jan 22, 2003 01:48 AM
