Which wideband to use?
Old Nov 27, 2011 | 06:47 PM
phat00civic's Avatar
Default Which wideband to use?
I am looking at purchasing an 02 wideband sensor. I am mixed between Innovate and PLX in terms of brands. I will be using this on a D16, an ODBI, not ODBII ECU tuned on crome. Looking for some thoughts or ideas on what you think about these or others. In the past I never used one as I would bring it to a tuner and then that was it, so my experience in picking one for myself is that much harder. Thoughts?
Old Nov 27, 2011 | 07:02 PM
vietjdmboi's Avatar
Default Re: Which wideband to use?
ive had great success using the aem digital gauge one.
Old Nov 27, 2011 | 07:30 PM
cibao2ner's Avatar
the best would be the ngk afx...has the best o2 sensor...but sensor its expensive....then innovate mtxl is working good for me and uses same bosch sensor as aem and most other widebands...i got the mtxl for 170 on ebay..
Old Nov 27, 2011 | 07:33 PM
Spawne32's Avatar
anything that uses NGK sensors, i go through bosch sensors like toilet paper
Old Nov 27, 2011 | 07:44 PM
So would you say you have spent close to $300 on the bosh sensors + the kit? If so how long did it take you? I believe the NGK kit is like $280.
In terms of it going bad I am not too worried about it as I am using it for tune / make sure as I drive nothing is going bad. I plan on leaving in the original and running another bung for it. The car has been tuned so its more of insurance then anything else.
Old Nov 27, 2011 | 07:48 PM
Spawne32's Avatar
Im on my 5th bosch sensor in about a year, at between 30-60 dollars a piece depending on whether or not i can get them at discount when i need them. I went through them about a month at a time when i was tuning the car, and the last two a few months on each.
Old Nov 27, 2011 | 07:51 PM
Good to know. Where is it mounted? I heard if you mount it in the wrong spot it will become destroyed that much faster. I remember reading somewhere about it being mounted at 3:00 rather then 9:00 or 12:00, or something to that effect when looking at the manifold / downpipe.
Old Nov 27, 2011 | 07:59 PM
Spawne32's Avatar
oem location in the downpipe
Old Nov 27, 2011 | 10:29 PM
siregcivic's Avatar
i use the innovative lc1 and i have tuned more then 16 cars with it with no problems whatsoever and i ran it in my personal car for 3 months with no problems and it still works
Old Nov 28, 2011 | 02:50 AM
wolve's Avatar
i've run the zeitronix unit with the bosch sensor since 2007 with no issues at all.
friend of mine have toasted his lc1 within 6months, now has a techedge and could'nt be happier
Old Nov 28, 2011 | 03:45 AM
ashb82's Avatar
aem look good but datalog like crap unless you have a aem ems.
Old Nov 28, 2011 | 06:09 AM
joe b's Avatar
Aem here and no problems . Original o2 sensor 5 years and counting ! No problems datalogging with hondata s300 .
Old Nov 28, 2011 | 07:02 AM
sleepencivic's Avatar
ngk afx with upgraded NTK sensor!! cant beat it for the price!
Old Nov 28, 2011 | 08:53 AM
Gunmetal_B20_Hatch's Avatar
upgraded sensor?? please elaborate. I love my NGK AFX and would like to know if i can make it even better.
Old Nov 28, 2011 | 09:00 AM
kyden's Avatar
all the new ngk afx's come with the ntk sensor.
Old Nov 28, 2011 | 12:15 PM
they have a bosch style and the ntk sensor as an option
Old Nov 28, 2011 | 01:27 PM
I am leaning towards the NGK although not sure of what benefits it has other then great quality.
Old Nov 28, 2011 | 01:44 PM
Ryan@FRP's Avatar
I have used AEM with great success.
Old Nov 28, 2011 | 03:46 PM
93ls10.0's Avatar
plx m300 here never had a problem also have a lc1 I haven't tried yet
Old Nov 29, 2011 | 09:33 AM
Am I correct in thinking that most of you that run FI do not run a wideband, only when tuning? It seems the majority of those that have FI do not have one. Do you run a narrow band (light show) one then?
Old Nov 29, 2011 | 09:35 AM
Spawne32's Avatar
I run a wideband 24/7 with my supercharged setup, and i use it for closeloop in ectune.
cibao2ner
38
Jan 9, 2012 09:44 AM
EGRhatch
May 15, 2011 11:29 AM
njebudalla
Feb 22, 2009 01:43 PM
rtnlsltn
Jul 4, 2007 11:55 PM
Asahi
Jan 1, 2005 04:06 PM
