Turbo rebuild? Who do u recommend?
I have a precision sc61 and was wondering of who to send it to for a rebuild? Or would it be better to just purchase a new one with it being sum what out dated now it that would be the better bang for the buck.. Thanks
Moderator
Re: Turbo rebuild? Who do u recommend?
You can rebuild and even upgrade with it by the time you go through all that. Ask Lighteningteg on here. He did the same thing. Give him a PM
https://honda-tech.com/forums/forced-induction-16/anyway-upgrade-older-sc61-2956430/
Sweet thanks... I already have the s cover.. the main think I was wondering if it would be better money wise to upgrade it when I have it rebuilt or just buy one of precisions new ones.. ive never had one rebuilt and was wondering for the money it would be better off buying a new one..
Moderator
Heh. you missed the point. He didn't upgrade to an "S" cover at all. it rebuilt it completely with Garrett components, a custom compressor wheel, and it performed better than when it was new.
Cost of rebuild/upgrade depends upon your budget and goals of what you're doing. Just because you get a newer unit, doesn't necessarily mean that it was the better choice.
Moderator
As I mentioned, you have a Turbonetics ceramic ball-bearing cartridge. your choices for rebuild locations will be slim. Its best to send back to Turbonetics directly in your case, or perhaps Precision which also uses a Ceramic ball-bearing cartridge of similar measurement.
sorry. i never had any experiences from blaast myself. i only heard good things.
since someone had a negative experience from blaast, i suggest you do NOT listen to my advice lol
Moderator
http://www.preludeonline.com/f69/bew...ilding-249259/
http://forums.focaljet.com/forced-in...uilding-2.html
http://www.theturboforums.com/smf/tu...uilding!/?wap2
http://forums.g2ic.com/showthread.ph...-Turbo-Rebuild
I typically don't talk about other shops and businesses in general online to the public without good cause (He who is w/o cast the first stone, right?). But in this case, I would avoid them...seriously.
Glad at least you had one good experience.
