wideband o2 bung placement
Re: wideband o2 bung placement (hotrod99)
i think most mfg usually recommends 12-18" from the turbine outlet. i always run them right after the first 90 off the turbo and have never had a problem.
Re: wideband o2 bung placement (CoreyR)
PLX recommends at least 24" and that is where ive had mine placed for over a year now with no problems.. and i run race gas full time..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLXDevices.com »</TD></TR><TR><TD CLASS="quote">Mount the wideband oxygen sensor before the catalytic converter and at least 24 inches downstream from your engine block or turbo for optimal performance. The sensor element will fail if it is exposed to exhaust gas temperatures above 850 deg Celsius.</TD></TR></TABLE>
Re: wideband o2 bung placement (mike93eh2)
mine is a whole 6 inches away here is the idea, at least this is what my tuner says, the closer the better, but it wont last long...
my buddy with a 13B has his 6" away also, and you know those rotary EGT's are HOT!! he has a different tuner than me, but he said the same thing.
Re: wideband o2 bung placement (mini-cRx)
Also, make sure you don't place it below the midline of the pipe (i.e., sensor facing "up" towards the sky). Moisture collects near the bottom of the pipe and can kill the sensor.
12-18 inches is best and dont be cheap about the insurance of your engine buy NTK sensors and EGT sensors to keep an eye on exhaust temps. because exhaust temps will let you know how good of a job your ignition system is doing. a wideband only tells you about the fuel system
Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">12-18 inches is best and dont be cheap about the insurance of your engine buy NTK sensors and EGT sensors to keep an eye on exhaust temps. because exhaust temps will let you know how good of a job your ignition system is doing. a wideband only tells you about the fuel system</TD></TR></TABLE>
dont mean to thread jack but i see a lot of people using bosche, is that bad compared to NTK? and good point on the egt vs a/f sensors, i never thought of that...
Re: (93turbo16)
i put mine right between the halfshaft and the firewall. i used to have it about 6-7" away from the turbo and i was toasting sensors monthly. ive had mine back a ways now with the plx for like 10k miles and no problemss
Re: (supergenius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supergenius »</TD></TR><TR><TD CLASS="quote">12 inches from the turbine here... Reads well... Race gas most the time get about 8k on a sensor</TD></TR></TABLE>
put it further away and i bet you get more out of it.
really.. there is no point in having a wideband sensor that close to the turbo.
Re: (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">
dont mean to thread jack but i see a lot of people using bosche, is that bad compared to NTK? and good point on the egt vs a/f sensors, i never thought of that...</TD></TR></TABLE>
The bosch sensor is much cheaper and easier to find than the NTK. The NTK is supposed to be more durable when using leaded/race gas, and in extreme conditions (lots of racing, high temps, etc.). If you've got a good tune and only run pump gas and have a good bung placement, the bosch will be just fine.
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">I always put them in the stock b-series location, basically right under the axles. That is far enough away and you can mount it vertically, which is ideal.</TD></TR></TABLE>
Re: (blinx9900)
exactly like borat said BUT
the NTK sensor will be more accurate, last longer with or without pump gas, and it is easy to find if you have a wideband that is compatible with a NTK sensor. IMO they pay for themself in the long run because you wont need to replace it as often as a bosch. (5) $80 bosch= (1) $160-$200 NTK
Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">^ Do you work for NTK? </TD></TR></TABLE>
haha no i wish, i have some crazy ideas and products i would like to develop
Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">(5) $80 bosch= (1) $160-$200 NTK </TD></TR></TABLE>
The bosch is about $50 at autozone. I'm on my 3rd in the last 2.5 years. I expect this one to last much longer than the first two, since I blew those learning to tune with uberdata and crome. Now I have ectune, and my AFRs are never as crazy as with those programs. WOT and most of part throttle was fine, but startup and idle and certain situations would get them down to 9:1 for minutes at a time!
boostincoupe
11
03-08-2006 04:16 PM
cr00klyn718
13
04-24-2003 01:28 AM
