Wich turbine housing too chose !??!
Old 02-23-2008, 12:51 PM
woolfgang's Avatar
Default Wich turbine housing too chose !??!
Hi
I built out a B20C5 ( b20a block with itr head ) that will have a redline set at 7500 rpm and want a gt3076r as turbo. but i have to chose turbine housing a/r .63 or .82 and dont know witch is better
i need some help here
thx
Modified by woolfgang at 2:10 PM 2/23/2008
Old 02-23-2008, 01:39 PM
SpoolnG2's Avatar
Default Re: Wich turbine housing too chose !??! (woolfgang)
What are your goals for the car? What will you be doing with it? How much boost do you plan to run?
The .82 will have a little more lag but will ultimately make more power up top. But depending on what your doing, it may not even be necessary.
Old 02-23-2008, 02:15 PM
Man U FTW
Schister66's Avatar
If its a stock sleeve block, the .63 will be plenty since you'll have to worry about cracking a sleeve before you'll run the turbo out of breath
Old 02-23-2008, 02:28 PM
Hulk22's Avatar
if your redline is set at 7500 you want the.63 it give you a better power band the .82 wont spool up till 52-5500 really no fun on the street if your going to get head work and up your rev to 85-9500 then i would go with with the .82. good luck
Old 02-23-2008, 04:55 PM
blinx9900's Avatar
Default Re: Wich turbine housing too chose !??! (Hulk22)
.63 housing for sure.
HUYNH
12-13-2006 05:21 PM
mrbsponge
04-12-2005 06:46 AM
FlySi
06-06-2003 08:16 PM
boosted hybrid
11-26-2002 03:16 PM
Quick Reply: Wich turbine housing too chose !??!
