why/when other oilpump gears? b16a-Turbo
Momently, I build up two b16a blocks (sleeves/align honing/girdles/rods/pistons etc.). Now, someone told me, that it would be better to replace the oem oilpump gears by aftermarket oilpumpgear (for example PRODRIVE).
In how far will I benefit, if I take these oilpumpgears?
Thanks
Thanks
Re: why/when other oilpump gears? b16a-Turbo (hondaapi)
Basically insurance for any car. I ran a few setups under 300whp with stock oil pump setup and no problems. For my current build I just spent the extra money for a piece of mind and went with the prodrive setup.
Re: why/when other oilpump gears? b16a-Turbo (g2turbo)
the extra money is not the problem.
I´d like to know why is it better and in how far do they differ to the oem-oilpumpgears?
you dont need a new oil pump gear. Guys take stock oil pumps up to 5-600whp. After that it might be a good idea to get a new oil pump gear. Dont get pro drive though ....seems like those are the ones always on here for shattering. If your gonna get one get a Toda. But really you dont need one. You could always get an ITR one since they flow more...but for your build i wouldnt go any further then that.
Re: why/when other oilpump gears? b16a-Turbo (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">you dont need a new oil pump gear. Guys take stock oil pumps up to 5-600whp. After that it might be a good idea to get a new oil pump gear. Dont get pro drive though ....seems like those are the ones always on here for shattering. If your gonna get one get a Toda. But really you dont need one. You could always get an ITR one since they flow more...but for your build i wouldnt go any further then that.</TD></TR></TABLE>
You sure? I thought all VTEC oil pumps were the same part number. . .
A fluidamper would be better insurance than a new oil pump gear, because even aftermarket gears have shattered too.
Why did you get an align hone? Were the clearances on the bearings off?
Re: why/when other oilpump gears? b16a-Turbo (m R g S r)
What is a fluidamper? I don´t know that (or at least not that word - I´m from Germany)
That reason why I did align hone was because I got new sleeves and let a 5point main girdle install. Everybody I talked to about main girdles told me to align hone after install and I for myself regard it as important.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaapi »</TD></TR><TR><TD CLASS="quote">What is a fluidamper? I don´t know that (or at least not that word - I´m from Germany)
That reason why I did align hone was because I got new sleeves and let a 5point main girdle install. Everybody I talked to about main girdles told me to align hone after install and I for myself regard it as important.</TD></TR></TABLE>
http://www.fluidampr.com/honda.htm its basically a crank pulley with a gel inside to absorb all the vibrations that cause the gears to break. it is indeed better insurance than a prodrive its $350 USD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">
Why did you get an align hone? Were the clearances on the bearings off?</TD></TR></TABLE>
on any motor without a stock girdle, when u crank the main bolts, this may cause a shift in the journals due to the fact that the tops of the mains (and maybe even the girdle) where not machined together.
I would also like to know if it messed with any clearances. My plan was to plastigauge my old bearing and determine if i need any thicker off that.
Re: why/when other oilpump gears? b16a-Turbo (Boosted Chemist)
over 700 hp all season
stock oil pump gear
stock crank pulley
still running strong (knock on wood )
james innes
stock oil pump gear
stock crank pulley
james innes
db1love
12-08-2010 11:27 AM
h22_crx
03-22-2007 04:01 PM
