Why is my torque so low????
Old Jun 26, 2003 | 08:58 AM
b00stedbyFastrax's Avatar
Default Why is my torque so low????
dynoed the car a couple of weekes ago. made 465 whp and 309 ft/lb @23 psi. after seeing other different dyno graphs , my torque seem to be fairly low. how can i tune for more torque?
set up : B18C1
83mm / 8.5CR
t4 turbo
portflow head and jg manifold.
Old Jun 26, 2003 | 09:17 AM
The Crow's Avatar
Default Re: Why is my torque so low???? (BoostedbyFastrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedbyFastrax &raquo;</TD></TR><TR><TD CLASS="quote">dynoed the car a couple of weekes ago. made 465 whp and 309 ft/lb @23 psi. after seeing other different dyno graphs , my torque seem to be fairly low. how can i tune for more torque?
set up : B18C1
83mm / 8.5CR
t4 turbo
portflow head and jg manifold.</TD></TR></TABLE>
Maybe the CR?
Old Jun 26, 2003 | 10:45 AM
lazerus's Avatar
Default Re: Why is my torque so low???? (The Crow)
smaller turbo will get you more torque.
the lower in the rpm band your engine creates power, the more torque there will be..
HP is a function of torque.
Old Jun 26, 2003 | 12:48 PM
MiraiZ's Avatar
yeah...I'd have to tend to agree that your T4 may be big...do you have a dyno graph?
Old Jun 26, 2003 | 01:25 PM
mskibbz-T's Avatar
Default Re: Why is my torque so low???? (lazerus)
I thought that the TD05-18G produced pretty low torque at higher boost levels... Like 200ftlbs on a 320whp setup on a B18C1, whereas a larger T3/T04E would produce more torque at the same whp... I'm confused
Old Jun 26, 2003 | 01:33 PM
DIRep972's Avatar
Smarter than you
If u run a turbo that is perfectly sized for ur motor it will produce the most balance of hp and tq. A real big turbo might not make high torque cause it is not efficient down @ say 5k rpm's but it will make alot more hp @ 8500.
Reason greddy makes weak tq and hp compared to a T04e is cause it is too small.
but fastrax- i agree ur torque is a little low for 23psi. usually a t04e @ 23psi is making closer to 350tq. what size turbo are u running? id say the low compression is contriuting too
Old Jun 26, 2003 | 01:38 PM
boosted92's Avatar
Default Re: Why is my torque so low???? (DIRep)
I think it's a combination of everything. Big mother of a T4 turbo, lower compression than most people run, the ported head and the JG edelbrock intake are all contributing to the lack of low end, IMHO.
Old Jun 26, 2003 | 01:46 PM
DLB1994's Avatar
Default Re: Why is my torque so low???? (boosted92)
its turbo size look at jinproof99 old setup ,low tq=big turbo https://honda-tech.com/zerothread?id=166892&page=
Old Jun 26, 2003 | 05:24 PM
thanks for all the input guys. went back to the dyno today, came out with 477whp and 315 ft/lb at 23 psi.
Direp: t67
Glove
Dec 30, 2008 07:31 PM
Phoenix1
Aug 29, 2005 08:47 PM
flip1199
Jun 18, 2005 01:37 PM
dunkd
Apr 25, 2004 02:48 PM
spaghizzle
May 1, 2003 07:11 PM
