vtec cleaning??
Old Feb 5, 2005 | 09:39 PM
AXZ NYC's Avatar
Default vtec cleaning??
my car seems like it's going in and out of vtec and i was wondering if it just needed to be cleaned?? if so how do i go about that??
thanks
Old Feb 5, 2005 | 09:52 PM
PredatorGSR's Avatar
Default Re: vtec cleaning?? (AXZ NYC)
Just pop it out and dip it in some soapy water, that should fix it.
Old Feb 6, 2005 | 01:25 AM
billyhoe's Avatar
Default Re: vtec cleaning?? (PredatorGSR)
vtec is dependant on rpm. maybe what ur experiencing isnt vtec i would say maybe the timing is off and the car is jerking. what is it doing exactly?
Old Feb 6, 2005 | 07:02 AM
MD94GSR's Avatar
Default Re: vtec cleaning?? (billyhoe)
timing would effect the vtec an cause the hestitation in the vtec? how much off would you notice a significant difference?
Old Feb 6, 2005 | 07:14 AM
Rory Breaker's Avatar
What do you mean in and out of vtec?
And what do you mean by "cleaning" vtec?
Old Feb 6, 2005 | 09:26 AM
mugenracer's Avatar
check your oil level, vtec is dependent on sufficient oil/pressure and if your low on oil this will cause the vtec to cut in and out if there isnt sufficient pressure.
Old Feb 13, 2005 | 09:07 AM
Phat4Door's Avatar
My boy had that same problem with his DOHC Del Sol, turned otu he only had 1 quart of oil in his motor.....he's not that bright.....
Chpwhtek
Mar 19, 2012 04:48 PM
JSpekBB4
Oct 30, 2007 10:23 PM
vietnogi
Apr 13, 2005 10:01 PM
CompressionFed
Mar 23, 2004 04:54 AM
jared703
Dec 13, 2001 09:46 AM
